Recreating This Texture? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 09:39 PM   #1
Question
Recreating this texture?
Rather than the orange-peel spray texture that was all over the house, we have been playing with textures as we redo various rooms. I saw this texture in the bathroom of a condo we rented and I'd like to try to duplicate it in a bathroom we are getting ready to remodel. Does anyone have some ideas on how it is done?
Closer view:
twostep94 is offline   Reply With Quote
Old 01-09-2011, 09:45 PM   #2
Rewards Points: 6,652
It would be a "comb" texture. A small tooth trowel was used after it was knocked down and let to sit for a bit.
The Following User Says Thank You to gregzoll For This Useful Post:
twostep94 (01-09-2011)
Old 01-10-2011, 11:57 PM   #3
Then the other part of the equasion is what is the material? One pigmented plasterers clay on top of the other then knocked down and combed? It is a nice effect presenting an old world charm. The pink went down with the green on top of it if my perceptions are correct and my dyslexic enhanced color and spatial faculities are intact
masterofall is offline   Reply With Quote
The Following User Says Thank You to masterofall For This Useful Post:
twostep94 (01-11-2011)
Old 01-11-2011, 08:18 PM   #4
So, as the DIY person who has only done some knock-down texturing, a search shows American Clay sounds like a product that might work with this, though all of their instructions talk about a really thin application, which sounds wrong from looking at the pictures. Are there other makers of clay plaster for home folks or maybe a DIY recipe for making it?
BTW - thanks to both of you for your comments, as they have helped a lot in this project.
Old 01-11-2011, 08:40 PM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 852
All purpose joint compound should work fine.
Just do some practice areas on a scrap sheet of drywall till you get it dialed in.
Sir MixAlot is offline   Reply With Quote
The Following User Says Thank You to Sir MixAlot For This Useful Post:
Old 01-11-2011, 08:43 PM   #6
What would you use to color it before applying, paint or some sort of other coloring?
Or, someone else suggested that possibly sponging on the colors afterwards might work.
Old 01-11-2011, 08:50 PM   #7
Rewards Points: 852
To me it looks like a Faux finish done with a rag.
The Following 2 Users Say Thank You to Sir MixAlot For This Useful Post:
DangerMouse (01-12-2011), twostep94 (01-11-2011)
Old 02-18-2011, 07:03 PM   #8
Think I know
This looks like some layered perlescent products like Can't Be "Suede" or Shine On with some burnishing wax over the top of it. It looks like the products are troweled with some kind of pronged tool run through it. Hope this helps!
fauxagoodtime is offline   Reply With Quote
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 09:00 AM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 07:24 AM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 05:09 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 04:50 PM
