Receptacles Wired Before Or After Blue Board? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-07-2013, 04:04 PM   #1
Rewards Points: 37
Receptacles wired before or after blue board?
I have a plasterer coming to hang blue board and plaster. Should I leave the wiring roughed in, or is it ok to connect the receptacles? Thanks!
SoxFan44 is offline   Reply With Quote
Old 07-07-2013, 04:20 PM   #2
CitadelBlue's Avatar
Rewards Points: 97
leave it roughed in .....Add receptals after painting ...
CitadelBlue is offline   Reply With Quote
The Following User Says Thank You to CitadelBlue For This Useful Post:
SoxFan44 (07-07-2013)
Old 07-07-2013, 04:23 PM   #3
Rewards Points: 37
Thanks man!
Old 07-07-2013, 06:11 PM   #4
DIY staff
Rewards Points: 7,174
What he said!!!!!
If you must add any switches or outlets before the board goes up---snap off the outside tabs that normally rest on the board---or the hanger will hate you.
ToolSeeker (07-07-2013)
Lennox Furnace with 63K8901 circuit board behaving strangely tgice HVAC 4 06-21-2013 02:03 PM
Deck ledger board attachment higher than rim board Davenger Building & Construction 0 06-20-2013 11:30 PM
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 01:21 AM
Green board, blue board, backer board??? ddougee Remodeling 5 03-21-2011 10:58 AM
Blue Board georgetax General DIY Discussions 7 11-11-2005 10:05 PM
