Reasons For Tape And Mud On Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-02-2014, 09:55 PM   #1
Rewards Points: 16
reasons for tape and mud on drywall
I don't have the links but saw two websites taking about level 0-5 quality for drywall and joints.
I am putting in a shower surround. Using greenboard, green mesh tape. The joint will be covered by the surround. I've done two days of mudding, the third will be done tomorrow.
The question is: is the tape and mud for strength of the joint, to stop cracks, or to make an overall smooth wall for appearance? I'm sure it is a combination of all three but it seems like the overall smooth appearance is the biggest factor. If I had a place where the appearance didn't matter at all, if I was going to put up paneling over the drywall, then I wouldn't have to tape or mud all all, right?
Thanks.
camplate is offline   Reply With Quote
Old 05-02-2014, 10:52 PM   #2
Rewards Points: 2,400
Correct, if you are going to panel your walls no taping or mudding needed.
I have done it just to have an extra layer of material holding up the insulation. And as a space holder around outlets, switches, etc.
ED
de-nagorg is offline   Reply With Quote
Old 05-03-2014, 10:55 PM   #3
Registered User
Rewards Points: 526
If in a heating/cooling climate, I'd tape just to stop air infiltration/exfiltration... as that is your air barrier in contact with the thermal barrier.
Gary
PS. Welcome to the forums!
The Following User Says Thank You to Gary in WA For This Useful Post:
federer (05-03-2014)
Old 05-07-2014, 11:49 PM   #4
the paper tape stops joints from cracking as easily, so if you're going to plaster behind the shower still put the tape in first so air doesn't get through if it cracks.
calypso121 is offline   Reply With Quote
Old 05-08-2014, 08:02 AM   #5
Rewards Points: 626
ED
Sorry correct code is to fire tape the walls before putting up the paneling.
Nailbags is offline   Reply With Quote
Old 05-08-2014, 10:26 PM   #6
Registered User
Rewards Points: 526
Not if under the IRC and wood paneling is 1/4" thick or more; http://publicecodes.cyberregs.com/ic...9_7_par020.htm
BUT, he needs an air barrier (back tape the seams on stud edge -perimeter, first) in contact while the thermal barrier (insulation); http://publicecodes.cyberregs.com/ic...002_par022.htm Check local AHJ.
Gary
Old 05-10-2014, 08:12 PM   #7
Rewards Points: 626
first off most people don't use 1/4" or greater paneling they use 1/8th so yes it is code. second I am glad to see that you agree that air movement is blocked by the sheetrock and not the insulation as you have stated before in other posts.
