Re-patching Drywall Multiple Times - Long-term Implications? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-14-2008, 11:48 PM   #1
Question
Re-patching drywall multiple times - long-term implications?
What are the implications of re-patching the same area of drywall more than once? I recently moved into a home (new construction) and the contractor has had to cut and re-patch various walls to access pipes--sometimes more than once on the same wall area.
Do drywall patches weaken the structure or cause problems over time, particularly if more than one patch in the same area has been made? Will this cause problems in the future? Thanks!
Cind is offline   Reply With Quote
Old 11-15-2008, 09:35 AM   #2
Registered User
Termite's Avatar
If the patches are done properly, there's no reason that they should ever be a problem at all. By "properly" I mean if they're backed with wood or their seams land on studs.
Old 11-15-2008, 12:27 PM   #3
Drywall contractor
Rewards Points: 1,070
Only thing I would worry about is making sure the new patch is cut out past the existing one so you don't end up putting on layer after layer of mud in the same spot. The buildup will eventually leave a hump which will be noticeable. Drywall isn't really considered part of the structural equation.........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-15-2008, 05:18 PM   #4
Thanks for the quick and helpful replies! As you have probably guessed, I'm a novice in this area.
Old 11-15-2008, 06:57 PM   #5
Drywall contractor
A new home can be intimidating (especially if it's your first). The best way to learn is from those who know.........this site is a great resource. Both experienced homeowners and pros are available to help. Best of luck.
Old 11-16-2008, 12:03 AM   #6
Patches and repairs are a fact of life. Whole walls can be repaired if needed.
Patching dry wall is easy to do.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-16-2008, 09:27 AM   #7
Rewards Points: 5,336
Sheetrock is not structural, so there would be no issue.
My question would be, why the contractor has to access the pipes behind the walls, again and again.
Ron
Tags
drywall , patch , repair , wall
patching painted drywall newb question afabco Drywall & Plaster 2 11-12-2008 07:58 PM
Prime before patching on drywall? DIYScott Remodeling 3 09-28-2007 10:19 PM
