Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-16-2009, 02:37 PM   #1
re: drywall compound over old lath
Hello,
I need to install drywall compound on my wall with the intentions of having a paint as the final finish. This is a bathroom located in the basement
Currently my wall has old drywall on it, with the paper surface removed (when i removed the old tile), exposing the gypsum core.
This is in a room with a reality high moisture.
I wish to have good adhesion with the drywall compound and the old gypsum in this high moisture area.
Do I need any sort of bonable primer before installing the compound, or any other adhesives.?
What drywall compound (product) would you recommend in this situation?
any thoughts would be appreciated
-gramps416
gramps416 is offline   Reply With Quote
Old 01-16-2009, 02:46 PM   #2
Remodeling Contractor
drywall with a paper face is not suitable for moist areas. Remove it. Replace it with paperless drywall. If all the paper is already off and you want to resurface what you have there then skim coat the entire surface with drywall compound and sand and prime and paint. To do this mix the compound in a 5 gallon bucket with a water to make a soupy mixture. Roll this onto the wall. Immediately knock it down with a 12" trowel. Option one is a better choice.
Old 01-16-2009, 02:52 PM   #3
are you saying that a standard drywall compound in this situation is suitable? with no bonding agents? If so what brand name product would you use?
Old 01-16-2009, 05:13 PM   #4
whatever brand is available. I do not know of any bad ones.
Old 01-16-2009, 06:27 PM   #5
Gramps:
If the gypsum core of the old drywall is exposed, then you need to replace the strength of the missing paper. Merely having paper on the back of the drywall isn't good enough. You need to have paper (or a reasonable substitute) on both sides of the gypsum to have a rigid wall surface.
Dilute white wood glue with water to make a paintable consistancy, and apply that to the bare drywall. Allow to dry and then apply strips of self adhesive fiberglass mesh drywall joint tape horizontally over the area where the paper is missing. Then, paint over those strips with the diluted white wood glue. As the glue dries, it will bond the fiberglass mesh to the gypsum core. Now do the same thing, only apply the fiberglass mesh strips vertically. And, paint over them again with the diluted white glue so that as it dries, it bonds those strips to the wall, too.
You have now replaced the strength of the missing paper with fiberglass.
Now, skim coat over that repaired wall.
If this wall is going to be in a wet area, like the shower, then you're best off removing the drywall completely and installing a product called "Dens-Shield" made by the Georgia Pacific Company or a cement board type material like Wonderboard.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-17-2009, 09:51 AM   #6
Drywall contractor
If thickness isn't an issue, put a layer of 1/4" drywall over the top of the existing wall and finish. Easiest fix. If you end up "glaze coating" the existing wall, I'd recommend a setting type compound for at least the first coat....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 11:57 PM
Applying Drywall Compound To Sheetrock shapeshifter Painting 9 04-29-2008 04:42 AM
Is all purpose drywall compound not strong enough? yummy mummy Building & Construction 3 04-23-2008 01:35 PM
Which drywall compound should I use? yummy mummy Building & Construction 16 11-12-2007 05:00 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
