Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-08-2013, 07:50 PM   #1
re-doing previously wallpapered walls
I took down wallpaper in one of my bedrooms and there is a ton of glue leftover on the walls, as well as some cracking. I'd like to re-do the walls before painting. Is it better to re-do the walls using durabond+joint compound or does a bonding agent+plaster veneer fare better? I have heard that joint compound is more forgiving, and there is less cracking. Thanks
The walls are rock lath.
debiasio is offline   Reply With Quote
Old 01-11-2013, 09:36 AM   #2
First forget the dura bond. Seal the walls with a sealer primer called Gardz. Then there is a new product out called fibraFuse not to be confused with Fibra Tape it comes in 36" wide rolls cover the wall with this then skim coat with the lite or ultra lite joint compound, sand, prime, paint. you can find the Fibra Fuse at all wall.com.
Old 01-11-2013, 09:47 AM   #3
BUt that glue on the wall needs to go first.
Old 01-11-2013, 10:02 AM   #4
GLUE??? chris is going to whup you with a wet noodle.
Old 01-11-2013, 05:30 PM   #5
paper hanger and painter
chrisn's Avatar
Glue, did I hear GLUE?
The PASTE residue needs to be removed before you proceed with whatever you are going to do.
Old 01-11-2013, 07:00 PM   #6
Sorry Joe tried to warn you.
Old 01-16-2013, 07:41 PM   #7
thanks for the tips. decided to leave the glue up and put a skim coat of veneer plaster over the wall. after they were sanded they looked great
Old 01-17-2013, 04:57 AM   #8
chrisn's Avatar
good luck with that
it could be years but I have seen that ADHESIVE ruin such a job
unless you applied inches of plaster over it.( the PASTE)
What paint can i use over previously painted concrete walls heidimae0325 Painting 7 02-08-2013 01:51 PM
What to paint over previously painted basement walls Atskodinski Painting 8 11-25-2010 06:08 PM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 10:41 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
Texturing a Previously Wallpapered Wall shapeshifter Painting 4 03-16-2007 05:14 PM
