Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-19-2011, 02:52 AM   #1
Raw edges on flood damaged drywall
A friend is trying to rebuild after a horrendous flood. He has horizontally placed drywall and has had to cut it at 4 feet or higher to remove damage. The edges are rough and he plans to put new board up and have professionals come in to tape, mud, and finish. Will they be able to get a decent looking job with butt edges meeting raw edges like this? His ceilings are about 9 feet. Thank you.
joelle is offline   Reply With Quote
Old 08-19-2011, 04:48 AM   #2
paper hanger and painter
chrisn's Avatar
Why can't he cut a straight line?
Old 08-19-2011, 05:39 PM   #3
Well, let's say he gets his lines straight. Can the raw edges (now straight!) and the butt edges line up well enough to make a nice join?
Old 08-22-2011, 05:18 PM   #4
Drywall contractor
If they truly are professional finishers, they will be able to finish the joints just fine. Your friend might want to get a pro to hang it also to make sure it's done properly also.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 09:32 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
Drywall Edges - bead or no? Ricky D Building & Construction 2 07-09-2007 08:52 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
