Quietrock And Green Glue For Soundproof Ceiling - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 01:15 PM   #16
Rewards Points: 150
Ted,
Could you elaborate as to how you are backing up your comment? Is there a study that you can reference that you forgot to put in your post?
I know there are many methods and tools to create "sound proofing", and I remember this as one of them. Mass loaded vinyl, iso pads, various insulation materials, etc.
By they way, this is not intended as an argument, I just like to learn as much as I can.
kgphoto is offline   Reply With Quote
Old 05-18-2010, 01:17 PM   #17
Soundproofing Guy
Rewards Points: 158
No problem whatsoever
http://www.nrc-cnrc.gc.ca/obj/irc/do...r766/ir766.pdf
This is a good place to start.
Ted White is offline   Reply With Quote
Old 05-18-2010, 02:17 PM   #18
Soundproofing Guy
Rewards Points: 158
Maybe another point would be of some value. There are 4 elements of sound isolation. Decoupling, absorption (what the insulation does), mass and damping.
Of these 4, absorption brings the least to the table. Typically 2-3 points is all. Surprising, and it seems intuitive that insulation would do more, but that's not the case.
Old 05-18-2010, 02:56 PM   #19
Rewards Points: 150
Thank you very much.
It is interesting to see that there was less with the RC on the studs verses between the layers. I wondered if the layer sandwich would have sealed the air penetrations and then the RC and 2nd layer would provide the decoupling, but I see that is not the case.
Old 05-18-2010, 02:58 PM   #20
Soundproofing Guy
Rewards Points: 158
Using RC on existing drywall is incredibly common. And so clearly not a good move. Maybe part of the problem is that no one is promoting the data found by the NRC to designers and architects.
