Quick Question-drywall In Bathroom - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 02:59 PM   #1
Rewards Points: 956
Question
Quick question-drywall in bathroom
Tore down the ceiling in the bathroom to renovate, etc. Is it a good idea to put drywall back up for the ceiling? Or should I use some kind of green board? And I also should use more glossy paint to paint the ceiling to prevent water penetration to the new drywall
federer is offline   Reply With Quote
Old 07-24-2012, 11:40 PM   #2
Rewards Points: 2,212
Yep, water resistant drywall and Bathroom paint.
mae-ling is online now   Reply With Quote
Old 07-25-2012, 06:28 AM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
Green or purple Sheetrock & semi paint not flat, flat will run if moisture gets to it.
JetSwet is offline   Reply With Quote
Old 07-26-2012, 09:47 AM   #4
Drywall contractor
Rewards Points: 1,070
Regular board is fine if the correct paint is used.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
chrisBC (08-09-2012)
Old 08-08-2012, 01:11 AM   #5
Rewards Points: 956
thank you guys. so the paint is just as important as the type of wall. gloss is the most water resistant right
Old 08-08-2012, 08:36 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use MR Board (Moisture Resistant Sheetrock) and a paint that either has a mildecide (anti-mold additive) in it, or, that has it added to it.
- Build Well -
Old 08-08-2012, 08:44 PM   #7
If you are remodeling the bathroom, you should put in an exhaust fan to help with the moisture. Make sure it exhaust outside and not in the attic. Good paint will take care of the rest.
Costa Rica Sun is offline   Reply With Quote
Old 08-08-2012, 10:54 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 340
MR board on ceilings requires 12" o.c. ceiling trusses, I'm pretty sure. Check the installation data sheet from the brand you're using.
Does anyone follow these specs? Not many, most carpenters and wallboard people don't even know the specs.
Jaz
Old 08-08-2012, 11:00 PM   #9
Rewards Points: 13,450
Never use a gloss paint on a ceiling unless you want every single flaw to show.
This is what I've been using.
http://rustoleum.com/CBGProduct.asp?pid=407
Old 08-08-2012, 11:11 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 340
Absolutely right Joe. But didn't you know that;(use)
Yikes.
I've never had a problem with ceiling paint, (which is flat of course), but I recommend Zinsser's Perma-White for bath ceilings. http://www.rustoleum.com/CBGProduct.asp?pid=346
Jaz
Old 08-09-2012, 12:03 AM   #11
Yeah I belive the MR sheetrock is only rated for ceilings with the framing at 12''. Not 16'' centres, not as strong as regular rock I guess.
I agree that regular rock-With a good bathroom paint, and proper exhaust in the room, will do fine.
chrisBC is offline   Reply With Quote
Old 08-09-2012, 01:02 AM   #12
Rewards Points: 956
thanks. i did install a new fan. vented out through the roof since the bathroom is the attic itself.
Old 08-09-2012, 01:03 AM   #13
Rewards Points: 956
thanks guys. i will look into the paint suggestions. as for the framing i believe they are actually 12 on center.
Quick Bathroom Plug and switch Question mclemenc Electrical 5 01-30-2011 10:02 PM
quick door and window question wengang1 Drywall & Plaster 4 12-09-2010 04:24 PM
Hanging drywall Question avtck Drywall & Plaster 6 01-05-2010 06:21 AM
painting new drywall in bathroom LittleBrownDog Drywall & Plaster 8 08-18-2009 06:53 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
