-   -   Quick question-drywall in bathroom (http://www.diychatroom.com/f101/quick-question-drywall-bathroom-151390/)
federer 07-24-2012 02:59 PM
Tore down the ceiling in the bathroom to renovate, etc. Is it a good idea to put drywall back up for the ceiling? Or should I use some kind of green board? And I also should use more glossy paint to paint the ceiling to prevent water penetration to the new drywall
mae-ling 07-24-2012 11:40 PM
Yep, water resistant drywall and Bathroom paint.
JetSwet 07-25-2012 06:28 AM
Green or purple Sheetrock & semi paint not flat, flat will run if moisture gets to it.
bjbatlanta 07-26-2012 09:47 AM
Regular board is fine if the correct paint is used.....
federer 08-08-2012 01:11 AM
thank you guys. so the paint is just as important as the type of wall. gloss is the most water resistant right
AtlanticWBConst. 08-08-2012 08:36 AM
Use MR Board (Moisture Resistant Sheetrock) and a paint that either has a mildecide (anti-mold additive) in it, or, that has it added to it.
Costa Rica Sun 08-08-2012 08:44 PM
If you are remodeling the bathroom, you should put in an exhaust fan to help with the moisture. Make sure it exhaust outside and not in the attic. Good paint will take care of the rest.
JazMan 08-08-2012 10:54 PM
MR board on ceilings requires 12" o.c. ceiling trusses, I'm pretty sure. Check the installation data sheet from the brand you're using.
Does anyone follow these specs? Not many, most carpenters and wallboard people don't even know the specs.
Jaz
joecaption 08-08-2012 11:00 PM
Never use a gloss paint on a ceiling unless you want every single flaw to show.
This is what I've been using.
http://rustoleum.com/CBGProduct.asp?pid=407
JazMan 08-08-2012 11:11 PM
Absolutely right Joe. But didn't you know that;(use)
:laughing:Yikes.
I've never had a problem with ceiling paint, (which is flat of course), but I recommend Zinsser's Perma-White for bath ceilings. http://www.rustoleum.com/CBGProduct.asp?pid=346
Jaz
chrisBC 08-09-2012 12:03 AM
Yeah I belive the MR sheetrock is only rated for ceilings with the framing at 12''. Not 16'' centres, not as strong as regular rock I guess.
I agree that regular rock-With a good bathroom paint, and proper exhaust in the room, will do fine.
federer 08-09-2012 01:02 AM
thanks. i did install a new fan. vented out through the roof since the bathroom is the attic itself.
federer 08-09-2012 01:03 AM
thanks guys. i will look into the paint suggestions. as for the framing i believe they are actually 12 on center.
