Quick Question For 1/4-3/8 Gaps. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 10:58 AM   #1
Rewards Points: 102
quick question for 1/4-3/8 gaps.
I know that the concensus is to use setting compound to prefill large gaps. I.m doing my first rock job and have a couple of joints where I had to correct for bad framing by leaving large (about 1/4 inch gaps) in the sheetrock. I'm using moldboard for a basement job. Is it ok to use the lightweight sheet rock setting compound (90) which I have or should I use durabond. Thanks.
Bonzoso is offline   Reply With Quote
Old 03-23-2013, 01:01 PM   #2
Rewards Points: 243
The 90 minute hot mud will be fine.
chemman is offline   Reply With Quote
The Following 2 Users Say Thank You to chemman For This Useful Post:
princelake (03-23-2013), ToolSeeker (03-23-2013)
Quick question with cement board and underlayment supastar1568 Flooring 7 01-05-2012 06:03 AM
Quick Wire Size Question leeave96 Electrical 5 08-22-2011 06:33 PM
Quick outlet question RodBarney Electrical 5 08-20-2011 01:06 AM
New here! Quick question. tmichelsons Building & Construction 5 06-15-2011 01:18 AM
Quick Bathroom Plug and switch Question mclemenc Electrical 5 01-30-2011 11:02 PM
