Quick Help - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 08:03 PM   #1
Rewards Points: 91
quick help
looking for some quick help - I have to close up a doorway in a bathroom asap. I removed the trim and put in my 2x4 - happy with that. One side of the wall is new(er) construction - 5/8" thick drywall. I got two big pieces of 5/8" drywall to cover both sides. Problem is, the other side of the wall is significantly thicker - 1 1/2" thick! I have some 1/4" thick wood, i was thinking taking some strips of 5/8" drywall and strips of 1/4" wood and using regular drywall screws, attaching them to the supporting studs, that gets me 7/8" out of the stud. Then putting 5/8" drywall with 2" drywall screws over the top, and I should be level.
Will this work? Safe? any advice, guidance, appreciated!!!
thx,
Matt
mmhendrie is offline   Reply With Quote
Old 07-14-2010, 08:17 PM   #2
what am i not seeing here? you have 5/8 drywall and are going to patch. nailed 2x4s on either side of the door frame for your firring strips. where does that 1.5" number come in? if you have 2x4 studs and the same drywall, what is making the wall thicker?
racebum is offline   Reply With Quote
Old 07-14-2010, 08:34 PM   #3
Rewards Points: 91
the 2x4's are in the middle following the door frame. on one side of the wall it's 5/8"s, good there. The other side of the wall has what looks like wood lathe, plaster, and then drywall over the top of that, making for a total width of 1 1/2" - so I'm trying to figure out how to level that with the 5/8" i've got
Old 07-14-2010, 11:47 PM   #4
Rewards Points: 91
*bump*
Old 07-15-2010, 10:44 PM   #5
Registered User
Rewards Points: 5,498
On the plaster side, cut the existing drywall back from the door enough to screw the new drywall on the plaster/lath. 1-1/2" or so. Add a 1 or 2x stud next to the center stud, sticking out flush minus the drywall on the plaster side. Side screw it to the new center stud. The drywall patch on the plaster side will be extra wide = 3" and extra tall = 1-1/2".
Be safe, Gary
Tarkett Vanguard Quick Loc Hardwood Floor wlwin61 Flooring 101 03-04-2017 08:25 PM
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
Shaw vs. Quick Step melissamarie9 Flooring 12 09-17-2010 09:52 PM
Quick Temporary Fix - Help!!! cressida Landscaping & Lawn Care 1 04-13-2010 01:06 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 02:25 PM
