Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-20-2009, 02:31 PM   #1
Quick connect fittings behind drywall
I am considering putting some quick connect fittings (like Watts or Shark-Bite) behind my drywall. Does anyone know if these connectors are likely to leak?
jgs1951 is offline   Reply With Quote
Old 07-20-2009, 02:56 PM   #2
Moderator
Termite's Avatar
They're no more likely to leak than any other fitting. The SharkBite fittings have ICC approval for use in concealed locations and burial...Not sure about the Watts ones.
Old 07-20-2009, 03:53 PM   #3
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
What he said ^^^^^ I really like the sharkbites except for the price. Me, I use them for convenience on small projects or if I have a situation where I cant dry out a fitting and get a good solder joint.
Brik is offline   Reply With Quote
Old 07-21-2009, 07:55 AM   #4
Thanks guys, your replies were very helpful.
Has anyone used the Watts Quick Connect Fittings? luweee Plumbing 8 02-28-2011 09:02 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
How to frame in-between joists for drywall? (quick Q) tigerbalm2424 Building & Construction 7 02-02-2008 07:43 PM
Quick connect sink? rick32 Plumbing 2 12-13-2007 02:07 PM
