Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-20-2012, 02:01 PM   #1
Question Regarding Drywall Cracks
We've notice several vertical cracks within our walls in our house. The cracks are always almost perfectly vertical (90 degrees).
I would not figure that these are settling cracks because they are almost symmetrical but I am not an expert either.
Here is a picture of one:
Does anybody know what type of cracks these may be? What would be the best route to take in order to get these fixed?
Phreek is offline   Reply With Quote
Old 07-20-2012, 05:03 PM   #2
paper hanger and painter
chrisn's Avatar
looks like a badly installed corner bead to me
there are better qualified drywall guys that will let you know whats up and how to fix. I know what I would do but I would wait for the experts
Old 07-22-2012, 10:55 AM   #3
Yikes! Is it extensive?
Old 07-22-2012, 11:20 AM   #4
i would scrape out the plaster. put screws in the corned bead. and replaster.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 07-22-2012, 08:51 PM   #5
Looks like the 50 grand "remodeling" job the previous owners had done to "finish" the lower level of my house back in the '80s.
In my case there were no nails, screws, or even evidence of a crimper used on any of the corner bead anywhere.
They also did cute stuff like leaving taped-up live wires wrapped around a water pipe.
Many trips to the dump later, there's no evidence these monkeys were ever here.
Your problem is more easily remedied (I hope) by just screwing in all the bead and refinishing the corners.
thatbobguy is offline   Reply With Quote
Old 07-26-2012, 10:58 AM   #6
Drywall contractor
Definitely corner bead "popped" loose. Nail/screw it back down and re-mud. That's why I've gone to the metal reinforced paper bead that is installed by mudding it on. You don't get these problems.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Ceiling Drywall question Mstrenke Drywall & Plaster 9 05-19-2012 12:09 AM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
curious cracks in drywall, plus door sag bleedpurple Drywall & Plaster 13 07-04-2009 04:01 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 04:05 PM
