Question About What To Do With Drywall And Lack Of Studs - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 07:04 PM   #16
kwikfishron's Avatar
Rewards Points: 618
Originally Posted by sublime2 View Post
How would he go about doing that?
Enlighten us.
Oh, and what about to the right,
Same thing?
Pretty easy to block between the studs under the cabinet on the left and attaching more backing to the left stud on the left side. Can't see the right side but I guarantee there’s a fix without pulling the cabinets.
kwikfishron is offline   Reply With Quote
The Following 3 Users Say Thank You to kwikfishron For This Useful Post:
drywallfinisher (07-17-2013), TheEplumber (07-03-2013), ToolSeeker (07-03-2013)
Old 07-03-2013, 07:05 PM   #17
Rewards Points: 155
Enlighten us.
Same thing?
to the right there is a stud that i can easily attach the drywall to.
rygar is offline   Reply With Quote
Old 07-03-2013, 07:11 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 684
You don't need to attach to a stud and you don't need to go to the top plate.
Simply clean your existing cut lines square to each other. Then put some backing behind the edges and cut your patch to fit.
Old 07-03-2013, 07:14 PM   #19
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
will attempt to remove cabinet.
best steps to take to guarantee its placed back in the exact spot?
When replacing cabinet attach a piece of wood directly under and against the existing cabinets that will extend to the area where the reattached cabinet will go.
Make sure it's level, then use this wood to support the cabinet your installing until it is secured to the wall and the other cabinet. .
sublime2 is offline   Reply With Quote
Old 07-03-2013, 07:20 PM   #20
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Good luck getting the mud on the edge of the cabinets.
Old 07-03-2013, 07:22 PM   #21
Rewards Points: 13,750
And you can not run an extension cord behind drywall, going to need to run romex and an outlet.
Old 07-03-2013, 07:33 PM   #22
Rewards Points: 618
Very doable if you have the skillset, otherwise trim is your friend.
Old 07-03-2013, 07:37 PM   #23
Plumber
Rewards Points: 684
I understood the backsplash is being replaced as well
Old 07-03-2013, 07:43 PM   #24
Rewards Points: 155
yes putting up white subway tile on this drywall
Drywall Knife Question. hboogz Drywall & Plaster 10 06-26-2013 02:47 PM
Cut-In box question solidworks400 Electrical 15 02-20-2012 01:54 PM
Finishing Attic, insulation question pjgsteelers Remodeling 1 07-13-2010 01:59 PM
Drywall over tile? Roxie525 General DIY Discussions 8 06-11-2010 04:46 PM
roofing and insulation question everyman Building & Construction 23 06-12-2009 07:32 PM
