Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-08-2011, 08:40 PM   #1
808
Quarter round to Drywall
My house here in Hawaii is steel framed, the interior walls are textured drywall with bullnosed outside corners, the existing floor is carpet - no baseboards.. I'm about to put down laminate flooring, any advice regarding mounting quarter round ? I have a small compressor and brad/finish nailer.
808 is offline   Reply With Quote
The Following User Says Thank You to 808 For This Useful Post:
charlie5ive (08-29-2011)
Old 08-12-2011, 08:32 PM   #2
I'm in Calif where almost all high end homes use "bullnose" at the outside corners. You have to use two 22.5 degree cuts to go around the corner. then caulk the gaps on top where they meet. Sorry... I'm from the Midwest and hardly ever used bullnose cornerbead. But out here I guess they are not as coordinated out here and run things into the walls a lot more!! lol
Johnboy555 is offline   Reply With Quote
Old 08-12-2011, 09:38 PM   #3
NACE Coating Inspector
mustangmike3789's Avatar
HAWAII,,,, i will be in oahu in about two weeks. a friend of mine has a house on Lanika beach that i stay at about once a year. the house is about 15' from the water and the view of the mokulua islands is amazing. i may hop to the big island this trip due to the recent lava flows. i will say that the older ways of building in hawaii is some of the most unusual that i have seen. im guessing that you dont have any dead wood placed in the walls between your metal studs and your floors are probably concrete. i have ran into this before and had to shoot the nails at sharp angles while alternating the direction of the nails. fill your nail holes and caulk eveything in. im sure that someone may chime in with a better option.
mustangmike3789 is offline   Reply With Quote
Old 08-12-2011, 11:21 PM   #4
I have used a new (last 5 years) product called "Power Grab" that seems to work great for mounting moldings without nailing. It really grabs fast and holds like crazy. Especially great for those small pieces that might split if you nailed them.
Old 08-15-2011, 05:47 PM   #5
808
Originally Posted by mustangmike3789 View Post
.....im guessing that you dont have any dead wood placed in the walls between your metal studs and your floors are probably concrete. i have ran into this before and had to shoot the nails at sharp angles while alternating the direction of the nails. fill your nail holes and caulk eveything in. im sure that someone may chime in with a better option.
Yes thanks- concrete subfloor, new laminate flooring,
-that is the direction I was heading - finish nailer with 1-1/2" finish nails, shooting alternating angles and AVOIDING studs/sole plate footer since they're steel. Just not sure if this would be sufficient to hold the quarter round to the drywall? I guess a test run in the closet may be in order
Old 08-15-2011, 05:51 PM   #6
808
Thanks for your replies. I'll probably test run this option as well
Old 08-22-2011, 05:45 PM   #7
Drywall contractor
I recommend the adhesive with a few brads angled into the drywall to hold until the glue sets.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-22-2011, 06:04 PM   #8
808
So far it's working fine with the finish nailer, seems to be holding strong against the drywall with a 1.5" nail every 6-10 inches, then using adhesive to hold the small outside corner pieces.
Some mistakes, but pretty happy with my first attempts at this stuff; inside/outside corners and coping the inside joints
Old 08-22-2011, 06:11 PM   #9
m1951mm's Avatar
808, Your shoe looks really good. Very nice job on the outside corners!!! That Power grab is great stuff. Atleast it will not let loose if a valcano hits like the nails might, lol
Mickey
Fantasy Walls and Windows
m1951mm is offline   Reply With Quote
Old 08-22-2011, 08:32 PM   #10
Nice work! That's the way we have to do the corners out here in CA.
Vinyl quarter round question phil74501 General Discussion 6 04-08-2011 07:54 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
small quarter round moulding mf915 Flooring 11 09-30-2009 01:14 AM
Laminate Flooring Quarter Round Cuts no3jack Flooring 1 12-11-2006 09:30 PM
Quarter round and baseboard justtired Flooring 1 09-30-2006 05:39 PM
