Putting Up A Bathroom Cabinet - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 01:52 PM   #1
putting up a bathroom cabinet
I'm trying to put up a cabinet in my bathroom and I measured the distance painstakingly beween the nail slider hooks, but then I drilled the hole, put in the drywall anchor and the screw, and tried to slide the cabinet on - I'm like an 1/8th of an inch off. What do I do now? I'm afraid that if I pull out the screw and drywall mounts the mounts will break and I won't be able to use it and it's a special screw that fits into the holders on the cabinet.
newhomeowner85 is offline   Reply With Quote
Old 08-01-2010, 02:57 PM   #2
DIY staff
Rewards Points: 7,174
I need a picture to tell you exactly what to do.
However there are all sorts of anchor available,some that will not mind being installed next to a hole.
A tip to all-----when you need perfect spacing like this--don't use a ruler--
Use your level--hold it up to the cabinet or shelf or whatever and mark the hole locations right on the level-----then put the level on the wall--
and transfer the marks to the wall with a sharp pointed tool like a nail,awl or tiny screwdriver.
----Mike---
Priming and finishing previously painted bathroom vanity cabinet allinent Painting 1 01-25-2010 09:22 PM
Any issues with putting Allure flooring over a bathroom tile foor? BIGDOG2513 Flooring 1 03-05-2009 01:59 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
Tiling half a bathroom jeannieB Remodeling 9 06-20-2008 11:44 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
