Putting Drywall Over Drywall To Build Out Wall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 06:36 PM   #1
Rewards Points: 150
Putting drywall over drywall to build out wall?
For my bathroom project I currently have a 1 3/16 gap at one end of the tub. I was thinking I could layer board on top of board to fill it, 5/8 board and 1/2 board. Cement board around tub, drywall for rest of bathroom. Is that an ok fix?
If so is there anything I need to know when doing this? How should I go about stacking the boards, screws or construction adhesive?
Arsinek is offline   Reply With Quote
Old 03-16-2013, 07:31 PM   #2
Lord of Slums
Rewards Points: 1,974
I would think that to be fine, I would just pad the studs be it is up too you.
mj12 is offline   Reply With Quote
Old 03-16-2013, 07:33 PM   #3
Rewards Points: 150
What is padding the studs?
Old 03-16-2013, 08:16 PM   #4
Lord of Slums
OH, in your case, for example, cut four pieces of 2x4 one foot long, then nail one in each corner. Make the new pieces stick out past the existing stud. Their are many ways to do this, what ever you are most comfortable with. It maybe easiest for you to just layer the drywall in full sheets. Sometimes bathrooms and home theater rooms are double drywall for the soundproofing. Using nailers is more difficult to do in the beginning, but after awhile of hanging drywall it is the easier way to go
Old 03-16-2013, 08:19 PM   #5
DIY staff
Rewards Points: 7,174
Do not put drywall behind the cement board---unless the cement board is waterproofed the drywall could become moldy---
Use wood furring strips to 'pad out' the studs in the area to be covered with cement board---
Old 03-16-2013, 09:07 PM   #6
Rewards Points: 12,840
Post a picture so we can see why the walls so far off.
Old 03-16-2013, 09:45 PM   #7
Rewards Points: 150
Im thinking of "furring" the walls with cut 2x4. Rent a table saw and try to cut them to 1 3/16.
I got a bunch of pics here... How to replace this tub drain?
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Drywall over plaster over a block wall?!? DCRAM Drywall & Plaster 6 09-28-2012 06:03 PM
Soundproof wall performance rightit Drywall & Plaster 3 06-14-2012 09:43 PM
Framing basement exterior walls gheffron Building & Construction 7 06-08-2012 02:00 AM
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-13-2012 12:36 AM
