Purple Paste-used In Holmes On Homes To Fill Tiny Holes - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 05:06 PM   #1
Purple paste-used in Holmes on Homes to fill tiny holes
Hi fellow Diy'fers,
My tenants are leaving soon. They had this art work on the wall which was held by pins. There are about 50 tiny holes in the drywall now. What is the best way to fill it up without painting it afterwards?
Another question, I once saw Holmes on Homes and they used this purple paste, which I am sure turns white once dried, to fill tiny holes in the drywall. Anyone knows how it's called?
Thanks@!
greendot is offline   Reply With Quote
Old 08-02-2011, 05:11 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Don't have any idea what it is called but it is available at all big box stores. It is a brand of spackling compound.
XXX
Old 08-02-2011, 06:21 PM   #3
Learning by Doing
Leah Frances's Avatar
Any spackle will do. You DO NOT have to $hell out for the 'purple stuff'. A small tub of any kind of spackle should fill all your holes.
- Get a stiff putty knife
- dig up a small amount of spackle out of the tub (an amount the size of a walnut or smaller)
- spread it on the wall with the knife - hitting more than one hole if possible (assuming they are in a line and closely spaced)
- use the knife to scrape off any excess - don't leave any excess on the wall.
- wait for it to dry - it will shrink some and may leave some dimples - repeat as necessary.
- prime and paint
- feel good about doing it yourself.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-02-2011, 06:23 PM   #4
Thanks for the help.
Old 08-02-2011, 06:23 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
In college we used tooth paste.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
jschaben (08-02-2011)
Old 08-02-2011, 06:48 PM   #6
Learning by Doing
Crest worked better than AquaFresh. But we were the renters, not the Landlords.
Old 08-02-2011, 06:59 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OH! This is true.
XXX
Old 08-02-2011, 07:48 PM   #8
Tom Struble's Avatar
Rewards Points: 2,002
http://www.dap.com/product_details.aspx?product_id=217
Tom Struble is offline   Reply With Quote
Old 08-02-2011, 09:05 PM   #9
same here!
On another note, assuming the walls are some shade of white, if you were not going to paint (although that should be required between tenants,..) You can use a wet rag or sponge to wipe down the area, including the spackled spots. This will dull the new spackle, and make it blend in better with the surrounding paint. I have only used this method with white walls, so it may or may not work for other colors.
1910NE is offline   Reply With Quote
Old 08-03-2011, 08:00 AM   #10
Originally Posted by Tom Struble View Post
You gotta be kidding me. Painting wet spakle that big of a problem!
beerdog is offline   Reply With Quote
Old 08-03-2011, 10:25 AM   #11
^ Don't be a hater, that's the stuff the wife came home with for me! It works great
casper129 is offline   Reply With Quote
Old 08-03-2011, 11:31 AM   #12
drydex is good stuff,can be used outside when it's painted,maybe you know when it's ok to sand but some don't and it's not going to break anyones bank account
Old 08-03-2011, 11:52 AM   #13
Not being a hater. How much more is it? Being outdoor compaible makes it something more than spakle. It just seems so easy. spakle and wait 15 minutes or so. I always just spakle first and then do all the prep work. By then the spakle is dry.
Old 08-03-2011, 12:40 PM   #14
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Ha! I read "Holmes" and "Purple" - I was 100% certain I'd be popping into this thread to type "Spray-Foam".
CoconutPete is offline   Reply With Quote
Old 08-03-2011, 04:33 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
DAP - DryDex® spackling, America's #1 seller, contains a patented Dry Time Indicator causing the product to change color when optimum dry time is achieved. It goes on pink and turns white! This unique feature is the signal that it is ready to sand and paint. Easy to use indoors and out on drywall, plaster, wood, and more.
DAP must think everyone of us are morons.
Next time I have some outdoor drywall or plaster to repair I'll try to remember this product.
You might know that idiot Holmes would latch onto something like this. He's one of the morons that DAP has targeted.
XXX
Proper methods to fill concrete gaps, holes, cracks and resurface concrete jzam42 Building & Construction 6 07-21-2010 11:50 AM
Foundation Tie Holes - How to fill? globus999 Building & Construction 10 06-28-2010 10:14 AM
Right product to fill finishing nail holes? yummy mummy Building & Construction 14 11-06-2008 08:16 PM
What Can I Use to Permanently Fill Holes in Sump Pump "Poly" Tubing? kmcrawford111 Plumbing 12 06-27-2008 07:24 AM
Need to fill nail holes in drywall, what to use? twilightcall Building & Construction 3 05-12-2008 08:20 PM
