Purple Board And Joint Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 01:55 PM   #1
new member
Purple Board and Joint Compound
I promised to help my son finish his bathroom project. My job, since I've installed drywall and mudded before, is to bring the walls to a state where they could be painted.
I however am not sure what I got myself into this time. My son has installed purple board through out his bathroom. He told me that's what the home supply center recommned because his project was in a damp and high humid area.
My question is how do I finsih this purple board since there are no tapered edges where the drywall pieces come together? I even look at new piece at the home supply center and it has no tapered edges as well.
Won't this be impossible to finish with join compound or am I just not that experienced of a finisher to know how?
Thank you for your help...
-Ron
jtown67933 is offline   Reply With Quote
Old 05-12-2010, 03:20 PM   #2
Where are you located ?
Any pics of this purple board ?
What home supply center ?
Old 05-12-2010, 03:29 PM   #3
Rewards Points: 282
I got the purple board at Lowes. They told me it is the same as green board only purple. The board I got does have tapered sides. There are plenty of drywallers here that will give you tips but here is a link to get you started http://www.finehomebuilding.com/how-...tt-joints.aspx . Possibly you could treat the long joints as butt joints, but I'd wait and see what the experts say.
Jim F is offline   Reply With Quote
Old 05-12-2010, 08:08 PM   #4
new member
Thank You!
The material (Purple Board) was purchased at Home Depot and I can't believe it but it doesn't have tappered edges! I am wondering if this board is the type that should be used only if covered by a tub surround.
I live near Johnstown PA.
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
small cracks in joint compound JOINTS cody21 Remodeling 4 07-08-2009 10:09 AM
Strongest metal support to wood joint. Fixitgeorge Carpentry 1 05-05-2009 05:38 PM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 03:22 PM
Painting DensShield tile backer board warriorfox Painting 2 05-15-2008 04:08 PM
