Purple Board?? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 10:58 PM   #1
Purple board??
I am putting in a half bath. Toilet and sink only. My sink will touch a wall. How do I prevent sheetrock from failing from people splashing water on it as they wash up.?
Lafayette is offline   Reply With Quote
Old 03-10-2011, 11:08 PM   #2
concretemasonry's Avatar
Rewards Points: 2,566
What does that have to do with "purple" board - whatever it is where your are?
concretemasonry is offline   Reply With Quote
Old 03-10-2011, 11:09 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can install a tile backsplash.
You can use a proper washable paint.
XXX
Old 03-10-2011, 11:16 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the only purple board I know is impact resistant. I believe it has a fiberglass mesh embedded into it. It is not rated for use around moisture if I recall correctly.
and bud answered the actual question.
Old 03-10-2011, 11:21 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
In this area we now have MR drywall that is purple. It's real purdy!
Might be what that is.
I thought it was plaster-base but the owner assures me it was new MR.
XXX
Old 03-10-2011, 11:26 PM   #6
nap
You talking to me?
nap's Avatar
haven't seen MR in purple but since that isn't my trade, I don't see all the products out there.
I guess this company does make their MR in purple but it seems M means mold in that case.
http://www.nationalgypsum.com/products/product69.aspx
Old 03-10-2011, 11:30 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Maybe that's what he had!
Then it should be MMR board.
XXX
Old 03-18-2011, 08:07 AM   #8
Mold!! Let's kill it!
Rewards Points: 2,012
Yep. You can get purple MR board. Make sure you use the proper drywall mud and non organic tape. Regular drywall mud has organics in it that will mold, and paper tape..... well that goes without saying. Or use Densarmor drywall.
installing backer board over particle board bob mac Flooring 6 07-16-2013 04:15 PM
Purple Board and Joint Compound jtown67933 Drywall & Plaster 3 05-12-2010 09:08 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 10:41 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
