Protruding Edge Of Foundation - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 09:19 AM   #1
Protruding edge of foundation
Hi All,
I am looking for suggestions on how to drywall around or on top of a protruding foundation wall in my daylight basement.
fyrplace is offline   Reply With Quote
Old 09-08-2011, 02:32 PM   #2
Msradell's Avatar
Rewards Points: 210
The best way to do it, assuming the room stays dry is to use furring strips or dimensional lumber (depending on how large this step is) on the walls so that the sheetrock can extend to within about 1/2" of the floor. Then after you finish it the base molding will cover the gap. You could have the sheetrock end at the concrete and then cover it with molding or dimensional lumber, you wouldn't look as nice or be as formal vote would be fully functional depending on what you plan on using the room for.
Msradell is offline   Reply With Quote
Old 09-08-2011, 11:04 PM   #3
Yeah that's good thank you. The smaller edge is 1/2" and the larger is 2 1/2", furring strips on the smaller would work great.
Old 09-11-2011, 03:36 PM   #4
Drywall contractor
Rewards Points: 1,070
Be sure to use pressure treated lumber on any wood used in contact with the concrete...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
basement , drywall , foundation
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 10:40 PM
Foundation wall project and spread footings WillK Building & Construction 0 08-31-2011 12:46 PM
Ice and Water Shield under drip edge? sutterml Roofing/Siding 10 07-11-2011 05:04 AM
Insulating Old Concrete Foundation bjr149 Insulation 7 06-04-2011 08:42 PM
mulch against foundation??? fabian Landscaping & Lawn Care 2 05-08-2009 09:38 AM
