Proper Way To Repair This Wall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-12-2014, 08:52 AM   #1
Custom User Title
Rewards Points: 252
Proper way to repair this wall?
It looks like a window was leaking at one point (replaced before we bought the place) and the wall was never properly fixed. Before I started tearing into this, there was a "bubble" on the wall. Turns out that the top coat was separating due to the water infiltration. I pulled all of the loose plaster off and now I'm looking on what product to use to fix it.
I already have this stuff. Will it do the job?
no1hustler is offline   Reply With Quote
Old 05-12-2014, 09:29 AM   #2
Rewards Points: 12,812
I would remove the apron under the window before doing anything.
Remove any loose plaster.
Hit the bare areas with a mildicide and let dry. (if not the staining may bleed through)
Prime with Gardz primer, let dry.
Fill and tape that crack.
Then use regular light weight drywall compound, apply with a 12" wide drywall knife.
Prime that then paint.
no1hustler (05-12-2014)
Old 05-12-2014, 09:49 AM   #3
Custom User Title
Rewards Points: 252
Thanks Joe. The apron has already been removed. The white is the stool. Notice the difference in color paint. The tan was hidden by the apron when we repainted with the green almost 5 years ago. There was no staining coming through previously in the last 5 years but probably still a good idea just in case. Thanks for the tip. Is there a certain mildicide brand that I should look for? Can I find that at an Ace hardware?
Old 05-12-2014, 09:52 AM   #4
Bleach and water should work.
Old 05-12-2014, 09:58 AM   #5
Rewards Points: 5,974
One thing I might disagree with is get a little box of 5 minute easy sand and paper tape. That crack looks too big for lightweight mud, plus where it is with the window opening and closing it will be prone to cracking again and the easy sand is a lot stronger than regular mud.
The Following User Says Thank You to ToolSeeker For This Useful Post:
princelake (05-19-2014)
Old 05-12-2014, 10:22 AM   #6
joed's Avatar
Rewards Points: 11,552
I would use a setting compound not drywall mud. You can apply it thick and not worry about shrinking or cracking.
Old 05-12-2014, 10:40 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
Most "Fungicides" are mainly water. I would NOT spray any water on this. Remove what is loose and recoat it. Water has already caused the damage by loosening the white coat from the base plaster. What you have will probably work, but drywall compound will work too. It'd tape the crack in the base coat before applying a finish coat. A broad knife will make smoothing easier. Setting compound will be harder to sand and the repair is mainly cosmetic. No need to make this any harder than it needs to be.
Old 05-12-2014, 11:34 AM   #8
Custom User Title
Rewards Points: 252
Thank you for all the responses. Sounds like there are a few ways to go about it.
Old 05-12-2014, 11:45 AM   #9
The 5 minute is a setting compound.
Old 05-24-2014, 12:16 PM   #10
Rewards Points: 274
With this solution, i am really pleased to sort out the same problem faced by me a couple of week ago.
alexjoe is offline   Reply With Quote
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 08:49 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Old wall repair anonymoose Building & Construction 0 09-03-2012 03:28 PM
Proper gas line installation for wall furnace rsaritzky Plumbing 2 11-20-2010 01:39 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
