Problem Securing Outlet Box In Finished Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-18-2009, 04:31 PM   #1
problem securing outlet box in finished drywall
i have made the cut in the drywall to fit the outlet box and now i have a problem securing the outlet box with drywall finish. I try to angle 2 screws inside the outlet box but the outlet box doesnt stay flush against the wall and isn't leveled straight.
Any tips how to solve this problem?
pacheco is offline   Reply With Quote
Old 05-18-2009, 04:37 PM   #2
Electrician
Rewards Points: 780
Here in Canada we have these things, i am sure they have something similiar in the states
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
They go by the name 820D, or F clips, or steamships, probably more names for them that.
You slide it in the wall and the two parts that make the "F" wrap around and inside your box. They work really well for putting boxes in drywall walls.
darren is offline   Reply With Quote
Old 05-18-2009, 05:05 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Get an old work box and you should be good to go.
Old 05-18-2009, 05:29 PM   #4
Determine why it doesn't stay straight and take steps to resolve the isssue.
Seriously.....Sometimes a stud will be twisted a bit and you have to move the box in or out to split the difference.
If the drywall is cut straight along the stud and the screws are back into the box far enough to grab the stud, I don't know what the problem could be. Operator error ???
With the screws backed out or removed, hold the box tightly in position squeezing it toward the stud. Use low speed on your driver and run the first screw in, not all the way. Put the second screw in and use some finesse when snugging them up.
Is the side of you box completely flat? Some boxes have protrusions which can mahe them teeter. There may be something on the stud that is putting it out of whack?
I don't know. Look in there and find out.
220/221 is offline   Reply With Quote
Old 05-18-2009, 11:22 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
If you are NOT next to a stud, for old work the blue Carlon is #1
http://www.carlonsales.com/oldworknmbox.php
note (also works NEXT to stud)
If next to a stud, for old work 18.5 cu in
http://www.smartboxinc.com/Product.htm
If next to a stud, for old work 22 cu in the One-BOX
http://www.aifittings.com/whnew78.htm
note you'll have to get these boxes from an Electrical Distributer
no HD here
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-19-2009, 06:56 AM   #6
You can also improvise by putting a decora type switch cover ( open center) on the box while it is floating in the wall. Then fasten your screws through the switch opening while the cover plate works as a flange holding your box flush to the wall surface.
Then remove the cover and torque your screws down.
Chemist1961 is offline   Reply With Quote
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 05:15 PM
drywall potential problem mmhendrie Drywall & Plaster 8 04-04-2009 09:23 PM
Wiring Issue: Problem solving skkrman7482 Electrical 3 04-04-2009 07:32 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Anchoring a pedestal sink basin - stud or drywall anchor? AdamB5000 Drywall & Plaster 3 11-24-2008 02:42 PM
