Primer Peeling Off Brand New Plaster Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 09:32 AM   #1
Primer peeling off brand new plaster walls
I would liek to know what do I need to do to preapre a brand new plaster wall to prime it withoug fearing a possible pealing of the primer. I sanded the walls with a 150 grit sand paper and than with 120, I dusted the wall prior to priming and one or two days after I notices bubbles in certain areas I pulled on the bubble and the layer of primer came right off. I asked several frineds and they suggested I use oil primer. If put oil primers can I put a latex finish? or do you have a suggestion on how to prepare the wall so that the latex primer does not peal off?
luca93 is offline   Reply With Quote
rewiring house with plaster walls mattrussin Electrical 3 09-27-2010 07:41 AM
Plaster walls diybev Drywall & Plaster 1 08-31-2010 09:42 PM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 03:42 PM
Can you texture plaster walls? destes50 Painting 5 11-06-2009 09:51 AM
Plaster walls? Is it plaster? Lots of ?s UVAjenny Carpentry 6 04-15-2009 10:19 PM
