Primed New Ceiling Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 06:37 PM   #1
Primed new ceiling drywall
Hi all. Just finished priming a newly drywalled ceiling 10x24. Looks really good other than a few areas over mudded drywall screws. Although no noticeable ridges they are raised and can be seen under certain light. Do these spots show only because a primer coat has been applied and will they disappear after painted a couple times OR, will I need to sand these down further then re-prime and paint?
Thanks,
Gord
logcabinorchard is offline   Reply With Quote
Old 01-23-2013, 06:41 PM   #2
Rewards Points: 13,994
Hard to tell from here without a picture.
If you can feel it with your hand it's going to show when painted.
logcabinorchard (01-23-2013)
Old 01-23-2013, 06:58 PM   #3
Is it easy to sand down after being primed? Use 100 grit, sand down and then reprime?
Old 01-23-2013, 07:04 PM   #4
Easy no, got to be done yes.
jklingel (01-26-2013)
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
drywall or sheetmetal ceiling drmax Building & Construction 12 09-21-2012 08:15 AM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 09:11 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-07-2008 11:05 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
