To Prime Or Not? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 10:31 AM   #1
To prime or not?
Good day,
I just finished all the dry wall, taped and primed, now I going to spray texture on the walls, do I need to prime the texture after I spray for paint?
Regards,
Texascuda is offline   Reply With Quote
Old 06-11-2012, 03:30 PM   #2
Registered User
Rewards Points: 5,240
Prime before and after texture, A.2.3, pp.18 and A.4.3.1; http://www.lafargenorthamerica.com/G...%20English.pdf
And "prevent photographing": http://books.google.com/books?id=lO8...exture&f=false
Gary
Gary in WA is online now   Reply With Quote
The Following User Says Thank You to Gary in WA For This Useful Post:
All thumb's (06-11-2012)
Old 06-11-2012, 05:53 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Originally Posted by Texascuda View Post
Good day,
Regards,
YES
The Following User Says Thank You to chrisn For This Useful Post:
user1007 (06-14-2012)
Old 06-14-2012, 07:55 PM   #4
Too Short? Cut it Again!
Absolutely!And I would use a high-build primer to even out the texture a bit.
Should I prime Trvlr Painting 6 06-04-2011 06:29 AM
Shallow wells loses prime rosberney Plumbing 20 01-26-2010 08:56 PM
to prime or not to prime? re: metal siding... annie68164 Painting 3 05-24-2009 08:58 PM
prime then texture or texture then prime jeerme Painting 8 01-23-2009 10:25 AM
Bath Remodel- Prime then Mud, or Vice Versa steve65 Painting 11 02-28-2008 01:54 PM
