Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-16-2010, 01:49 PM   #1
Unhappy
Prime before Knockdown?
Want to do knockdown on walls, walls are a painted panel board. Do i need to prime before since its been painted already? Someone at home depot said to put about 1 cup of Gripper paint in the dry wall compound and you do not need to prime . Has anyone heard of this. Planning on painting the wall after.
finmil is offline   Reply With Quote
Old 03-16-2010, 11:00 PM   #2
jlhaslip's Avatar
sand to remove any paint which may not be adhering well. Not required to remove all the old paint, just scratch it up a bit.
prime and texture. prime again and then paint.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
finmil (03-17-2010)
Old 03-17-2010, 04:32 AM   #3
paper hanger and painter
chrisn's Avatar
Do NOT listen to what anyone that works in the paint department at the big box stores says, they typically have as much experience as a 5 year old.
The Following User Says Thank You to chrisn For This Useful Post:
finmil (03-17-2010)
Shallow wells loses prime rosberney Plumbing 20 01-26-2010 08:56 PM
Primer before knockdown? perpetual98 Painting 6 09-27-2009 06:55 AM
to prime or not to prime? re: metal siding... annie68164 Painting 3 05-24-2009 08:58 PM
prime then texture or texture then prime jeerme Painting 8 01-23-2009 10:25 AM
What first ?! Ceiling or Walls? Do I need to prime? yohan Painting 6 07-26-2008 11:35 PM
