Preparing Drywall Mud, All Purpose Green Bucket - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-06-2013, 07:24 PM   #1
Rewards Points: 150
Preparing drywall mud, all purpose green bucket
Ok, so I bought some Sheetrock All Purpose mud in the green lid container. How do I go about preparing it? Some of yall mentioned mixing water into it.
Arsinek is offline   Reply With Quote
Old 06-06-2013, 07:50 PM   #2
Rewards Points: 13,732
Just use it out of the bucket for the first and second coats.
On the last coat you may need to add a tiny amount of water.
Going to need a paddle and a Heavy duty 1/2 drill.
Old 06-06-2013, 08:00 PM   #3
Rewards Points: 150
I already have one of these...
http://www.lowes.com/pd_176765-51872...xer&facetInfo=
Would that be enough?
Old 06-06-2013, 08:09 PM   #4
DIY staff
Rewards Points: 7,174
This is what I do---thin what is needed for the tape---for the first coat after the tape, I like it as is,after mixing----then like Joe mentioned top coat thinned a bit---
I never use green for the top coat---I'm lazy and prefer blue lid for the top coat--it's much easier to sand.
MTN REMODEL LLC (06-09-2013)
Old 06-06-2013, 08:43 PM   #5
Rewards Points: 528
i use 20 minute for all coats. you guys are just not working fast enough!
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
firehawkmph (06-07-2013)
Old 06-06-2013, 08:56 PM   #6
Old School
Willie T's Avatar
For a beginner, please don't let yourself be sucked into the trap of using any quick mud at all.
You are not racing the clock for a paycheck. And you need time to think about your next steps, and the freedom to be a little relaxed in what you are doing.
FranÁois Duc de La Rochefoucauld
Willie T
The Following 3 Users Say Thank You to Willie T For This Useful Post:
MTN REMODEL LLC (06-09-2013), Nailbags (06-07-2013), ToolSeeker (06-07-2013)
Old 06-07-2013, 12:27 AM   #7
Rewards Points: 626
I always thin my mud out about pint or half pint of clean water. Mix good and take your time.
Nailbags is offline   Reply With Quote
Old 06-07-2013, 07:38 AM   #8
Rewards Points: 5,974
I also agree with mixing water for several reasons, ease of application, helps wet the tape (reducing bubbles) and when you pull it the excess comes out from under the tape a lot easier. That mixer you have is about the worst as it is really a paint mixer. This is what you should have gotten http://www.lowes.com/pd_245395-51834...ductId=3054665 maybe take the other one back. Even if you decide not to add water you need to mix the mud before you use it.
Old 06-07-2013, 06:05 PM   #9
Rewards Points: 150
Ive had that one for years, bought it to mix paint. lol. But figured if I could get away with using for mixing joint compound why not.
So youre saying put water in the whole bucket? Or put some mud in a mud pan and mix some water in that?
Old 06-07-2013, 06:53 PM   #10
If you are not using additives put water in the whole bucket. If you are going to use additives such as Mud Max just mix it in what you can use. The additives make the mud hard to sand, so if you mix the whole bucket your final coat will be hard to sand.
Old 06-07-2013, 07:21 PM   #11
Rewards Points: 626
Yeah when I use mud max I just use one box of mud just for that for the taping and setting beads after that I toss the mud and use the all purpose mud and I always mix in a min half pint of water. See how it works and add more as I need to no more then a pint.
Old 06-07-2013, 07:30 PM   #12
Rewards Points: 4,796
Bush league. I use all 5 minute....
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Old 06-07-2013, 07:33 PM   #13
You can also take some of the compound out and put it in another bucket, and mix it by hand with this
http://hostedmedia.reimanpub.com/TFH..._DRYWAL_01.JPG
It's easy for smaller batches. Mixing is more important than water - it's surprising how creamy it gets even without water. Water can also help, and is almost mandatory for warm weather taping, especially with a fan going. You might need to add a bit of water every hour.
Old 06-07-2013, 07:35 PM   #14
Rewards Points: 150
Ok. So a pint to half a pint in the bucket of mud?
And I guess Ill go get that other mixer. Been spending tons of money at Lowes for the past almost 10 years why stop now?!
Old 06-07-2013, 07:55 PM   #15
Rewards Points: 626
Yes one oz per gallon of mud so in a five gallon bucket there is really about four gallons in there. I start off with a half pint and work up from there no more then a pint of water. The reason to do that is to have the mud as you embed the tape and run your six inch knife over the tape is to get the air out and the extra mud out. Hope that helps and just don't over work the mud or the tape do the tape and corner beads let it sit for twenty four hours after you done. then do your first coat let that dry and go back the next day so forth and so on.
Drywall Damage After Wallpaper Removal katega Painting 10 01-26-2012 10:21 PM
Green is the New Black aaron.klimchuk Green Home Improvement 36 02-17-2009 09:07 AM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 02:20 PM
Mold on Green Drywall - how to remove? TotallyLostAlisha Drywall & Plaster 4 08-05-2008 06:47 AM
Drywall differance betwn green and standard SeanR Building & Construction 6 10-21-2007 08:17 PM
