Prep Work Before Skim Coating - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 11:53 PM   #1
Rewards Points: 27
Prep work before skim coating
what are the necessary steps to take before skim coating a painted wall? I need to skim the whole room because the texture is just absurd.
woodenSpoon is offline   Reply With Quote
Old 12-17-2011, 03:47 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
Lightly sand it down, clean it, skim
Old 12-17-2011, 11:12 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
You may notice that sanding a painted wall is next to impossible.
You may consider hiring a professional if you're doing a large area. It could end up worse than before you started.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-17-2011, 12:22 PM   #4
retired union carpenter
Send a message via Yahoo to coupe
I agree with Titanmen, especially if there are two or more coats of paint? get a bunch of sanding poles and paper, a keg of beer, invite all the neighbours, and have a sanding party?
or just start skimming and use a plasterer's float
good luck
coupe
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-19-2011, 03:05 PM   #5
Rewards Points: 27
Would the green top joint compound work or should I be using plaster...out does anyone have a better suggestion
Old 12-19-2011, 07:12 PM   #6
I've never worked with plaster-plastering is a specialty trade in itself.
if the texture isn't too deep? USG green lid compound should work. I'd start with applying it with a concrete finishing flat trowel, start i one corner, working an area manageable. may 2' square? to start and see how it is going to work? as it dries you can run the trowel over to smooth it to your liking and can removes most if not all trowel marks
if it begins to dry too fast, a simple spray bottle can wet it just enough to keep it from rolling onto itself. if it's too thick you'll get cracks, keep the trowel clean, if small hairline cracks? a little spray will allow you to go over again.
don't try too big an area at a time! it may take you a while to get the hang of it, be patient and allow to dry a bit while trying to fill texture. it may take a couple days? depending on size of room ad finish you want?
when all done and dry, a damp sponge mop will fill in small cracks and imperfections. just rub gently. to not soak the drywall paper and roll it off
if needs second coat? do same way. with patients and work you can get it as smooth as glass. when you're happy with the look, lightly sand with a fine grit paper and paint.
as always, just my thoughts!
good luck
coupe/Larry
Old 12-19-2011, 09:10 PM   #7
Rewards Points: 27
Thanks coupe. That was really helpful
Skim Coat Tools? Knives, Trowel, or Magic Trowel?? Lovegasoline Building & Construction 7 08-01-2012 11:25 PM
Can homeowner (or friend) rewire in California? cvandewater Electrical 34 01-14-2012 01:04 PM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 05:17 AM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 08:07 PM
