Predrill Drywall And Stud? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 09:56 AM   #1
Predrill drywall and stud?
I am trying to install drywall in a kitchen of an old home.
When I try to screw drywall screw into stud some have broken and some will not go in.
Is it ok to hold rock inplace and predrill before screw?
bjlffire is offline   Reply With Quote
Old 01-28-2010, 01:13 PM   #2
jlhaslip's Avatar
Rewards Points: 2,162
yes, that would work, but don't break the paper when you install the screws. Are you using a drywall gun as a driver? set the nose cone correctly and you will have no problem.
jlhaslip is online now   Reply With Quote
Old 01-28-2010, 01:23 PM   #3
Too Short? Cut it Again!
Sure the screws you are using are of quality? I work mostly on antique things and some of that old lumber has aged to be hard as a rock. It is pain, but sometimes som parafin on the screws helps.
Old 02-04-2010, 10:57 AM   #4
Drywall contractor
Rewards Points: 1,070
Also you can use fewer fasteners if you use drywall adhesive.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 04:34 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
drywall potential problem mmhendrie Drywall & Plaster 8 04-04-2009 08:23 PM
Anchoring a pedestal sink basin - stud or drywall anchor? AdamB5000 Drywall & Plaster 3 11-24-2008 01:42 PM
