Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-31-2011, 11:40 AM   #1
powder vs premixed
I tried searching but did not find a specific thread topic. I am curious what peopel prefere. Powdered or premixed as far as mud.
beerdog is offline   Reply With Quote
Old 03-31-2011, 11:45 AM   #2
Experienced
Jackofall1's Avatar
powder vs premixed
Powder is good for plaster repair jobs, premix for drywall. At least that is how I have done it.
Mark
Old 03-31-2011, 11:49 AM   #3
Learning by Doing
Leah Frances's Avatar
powder vs premixed
Powder. You can't beat knowing when it will be dry, and being able to do step 2 WAY sooner.
Patching a nail hole? I would probably use pre-mix or spackle.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-31-2011, 12:19 PM   #4
powder vs premixed
pre mix allows for erors you dont race the clock trying to empty a pan full b4 it sets up and its easier to sand short cuts is for those who cant hang in the race
lrobertstoner is offline   Reply With Quote
The Following User Says Thank You to lrobertstoner For This Useful Post:
Willie T (03-31-2011)
Old 03-31-2011, 04:00 PM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
powder vs premixed
Beerdog, Also, if your going to be using fiberglass mesh tape you must use the hot mud (powder).
-Paul
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 03-31-2011, 04:05 PM   #6
Wire Chewer
Red Squirrel's Avatar
powder vs premixed
I've always used premix, but never tried powder.
Old 03-31-2011, 04:38 PM   #7
Learning by Doing
powder vs premixed
I've never had to race. I just don't mix more than I can work in the time period. I was afraid to use it before I ever did; but now I know the benefits.
Also, you can get ez sand powder.
Old 03-31-2011, 04:41 PM   #8
powder vs premixed
I prefer pre-mixed. Yes, it takes longer to dry, but you have more time to work with it. It sounds like mudding is something you haven't done a lot of and for that reason alone I would recommend pre-mixed.
Rick
http://myhandyadvice.blogspot.com/
sharpsport is offline   Reply With Quote
Old 04-01-2011, 01:42 AM   #9
Too Old
powder vs premixed
It depends on the size of the job for me. If it is an area that I can tape and mud in a couple hours then I might use hotmud, mixing the mud takes time. If it is a bigger job I use all purpose because I can mix 10 gallons at a time.
havalife is offline   Reply With Quote
Dishwasher powder instead of salt - Doh! Bottletops General Discussion 0 03-03-2010 12:06 PM
Premixed Thinset jmoe Tiling, ceramics, marble 5 02-18-2010 04:32 PM
gun powder Ram Set windowguy Tools 15 07-20-2009 12:08 PM
Powder or Liquid Paint Nestor_Kelebay General Discussion 2 01-06-2009 06:05 AM
Powder Room Framing Question Not Sure Building & Construction 9 08-11-2006 07:13 AM
