-   -   powder vs premixed (http://www.diychatroom.com/f101/powder-vs-premixed-100147/)
beerdog 03-31-2011 10:40 AM
powder vs premixed
I tried searching but did not find a specific thread topic. I am curious what peopel prefere. Powdered or premixed as far as mud.
Jackofall1 03-31-2011 10:45 AM
Powder is good for plaster repair jobs, premix for drywall. At least that is how I have done it.
Mark
Leah Frances 03-31-2011 10:49 AM
Powder. You can't beat knowing when it will be dry, and being able to do step 2 WAY sooner.
Patching a nail hole? I would probably use pre-mix or spackle.
lrobertstoner 03-31-2011 11:19 AM
pre mix allows for erors you dont race the clock trying to empty a pan full b4 it sets up and its easier to sand short cuts is for those who cant hang in the race :whistling2:
Sir MixAlot 03-31-2011 03:00 PM
Beerdog, Also, if your going to be using fiberglass mesh tape you must use the hot mud (powder). :yes:
-Paul
Red Squirrel 03-31-2011 03:05 PM
I've always used premix, but never tried powder.
Leah Frances 03-31-2011 03:38 PM
I've never had to race. I just don't mix more than I can work in the time period. I was afraid to use it before I ever did; but now I know the benefits.
Also, you can get ez sand powder.
sharpsport 03-31-2011 03:41 PM
I prefer pre-mixed. Yes, it takes longer to dry, but you have more time to work with it. It sounds like mudding is something you haven't done a lot of and for that reason alone I would recommend pre-mixed.
Rick
http://myhandyadvice.blogspot.com/
havalife 04-01-2011 12:42 AM
It depends on the size of the job for me. If it is an area that I can tape and mud in a couple hours then I might use hotmud, mixing the mud takes time. If it is a bigger job I use all purpose because I can mix 10 gallons at a time.
