Powder Room Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 03:40 PM   #1
Rewards Points: 1,062
Question
powder room drywall
does powder room drywall need to be the green type that is moisture resistant or can it be the regular kind because there is not so much humidity in a powder room (at least not as much as in a bathroom where you take showers)?
i plan to only have a tile baseboard with the rest of the walls just painted. i suppose that could make a difference.
thanks
Old 05-20-2011, 05:02 PM   #2
i would say since there is no tub or shower standard drywall would be ok as you were thinking.
The Following User Says Thank You to DannyT For This Useful Post:
amakarevic (05-20-2011)
Old 05-21-2011, 10:37 AM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
amakarevic, Or you could just put moisture board at the sink area just to be safe.
Also remember to keep all the drywall 1/2" off of the floor when you install it.
-Paul
Sir MixAlot is offline   Reply With Quote
Old 05-21-2011, 04:10 PM   #4
No, all you need is regular 1/2".
Green board should only be used around tubs and showers, and even then it's actually inadequate and the wrong material.
dberladyn is offline   Reply With Quote
Powder Room Floor allbymyself Flooring 26 10-06-2011 01:33 PM
Please comment on DWV for a new powder room teddynono Plumbing 2 09-10-2010 10:03 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Do I need Fire Resistant Drywall for this new room? vseven Drywall & Plaster 6 12-19-2009 03:00 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
