Possible To Fix Wrong Size Electrical Box Cuts? See Pics - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 10:08 AM   #16
Rewards Points: 236
Originally Posted by gregzoll View Post
You zip around the inside, then clean up by going just around the outside edge if need be.
i will try that, someday. i am done with drywall for a while.
Fix'n it is offline   Reply With Quote
Old 12-24-2012, 10:09 AM   #17
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
When I use a roto-zip. I plunge into the center of the box, move to a side, pull back and go outside the box. Then zip around the outside.
I used the Blindmark tool while hanging rock. With the Blindmark tool, you insert the magnet in the box (it has a nub that fits into the screw hole at the top and the bottom). you then tack up the rock, and use the other magnet to find the outlet boxes. Trace around the magnet, then use a rorozip tool to cut the line out. The secret to this is that the outside magnet (the finder) is about as big as the box itself. If you follow the line you made, your rotozip tool will be cutting around the outside of the box. As an added measure of safety, the magnet you install inside the box covers all of the wires as well.
Coastal South Carolina
Old 12-24-2012, 11:05 AM   #18
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
That box in the first pic is an "old work" box. The tabs at top and bottom go outside the rock.
sublime2 is offline   Reply With Quote
Old 12-24-2012, 12:58 PM   #19
retired union carpenter
Send a message via Yahoo to coupe
the trick is, learning when you need to run the rotozip clockwise or counterclockwise
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-24-2012, 03:00 PM   #20
Rewards Points: 6,652
Actually the trick is knowing how to use the tool, or tools at hand, to make the proper cuts.
Before rotozips, it would be measure twice, cut once, or use the pait trick.
Old 12-25-2012, 12:16 AM   #21
Rewards Points: 105
Ill second that. I have only done drywall a few times. I heard lipstick, not paint. I put it on the box, but it didn't come out great (I kept getting double lines for some reason).
I also did a marker (a long nail in a piece of wood pressure fit into box). I knew where center was, I tried to roto zip with a friends tool..... Holy crap! That thing was so fast, buzzing and bouncing on the inside. I scratched the crap out of the plastic box, and then nicked the wall when taking the tool out. I was terrible! Lol
I now use similar to that box, but I have one that goes into the box and has 6 small pegs (about 1-4" long, looks like thumbtac pins).
When you line up the drywall, you slap it and the pins stick into the drywall and the whole thing sticks on the sheet.
I then lay it face down and cut it with my drywall saw. Works great each time.
I think this is a picture of one (can't see the pins on the front due to angle):
Http://img.diynetwork.com/DIY/2005/0...312_4fa_lg.jpg
Sent from my iPhone using DIY Forum
jdm001 is offline   Reply With Quote
Old 12-25-2012, 08:43 AM   #22
Rewards Points: 236
the metal boxs are easy to zip. the plastic ones, if your not carefull, you will burn the plastic.
Old 12-25-2012, 10:29 AM   #23
A "Handy Husband"
rjniles's Avatar
The picture you posted looks more like the Blindmark tool with the magnets.
Like this
df
Old 12-25-2012, 11:49 AM   #24
Rewards Points: 105
Like this
df
Ah you're right. This is the exact one I got "Handymark" on amazon.
www.amazon.com/gp/aw/d/B000V5MPZM
Mixed reviews, but sounds like reviewers weren't lining up before using.
My first use I realized if I moved it into place or even swung it in, it might be a little off. I had great luck doing this:
First I lined up the top or bottom and put the edge in place while the bottom/top closest to the marker box hovering about an inch from the wall. I the even out the whole sheet 1" off wall and then bring back to wall so it's flat (perpendicular not swung in) and the box marks and usually sticks in too.
Easy to find, and then connect the dots to cut.
Old 12-25-2012, 12:25 PM   #25
A "Handy Husband"
rjniles's Avatar
Actually I don't use that Blindmark tool any more. What I do is put a mark on the floor directly below the box and write next to it the measurement up to the center of the box. Hang the drywall sheet from the top and leave it loose at the bottom. The box prevents it from going back to the studs. Measure up from the mark on the floor the distance I wrote. Plunge with the roto-zip and cut the box. Push the drywall back to studs and screw off.
Old 12-25-2012, 06:57 PM   #26
Rewards Points: 1,468
I can't tell you how many times I've had wire cut from someone using a Roto-Zip to trim around the inside of a box.
Sure, the wires should be set back deep in the box, but sometimes they're not. How do you know? They are covered by the rock....
Cutting inside the box is a BAD practice.
Shallow the bit in the Roto-Zip, cut around the outside of the box and you'll never do any damage.
ktkelly is offline   Reply With Quote
The Following 2 Users Say Thank You to ktkelly For This Useful Post:
mae-ling (12-26-2012), ToolSeeker (12-25-2012)
Old 12-25-2012, 09:52 PM   #27
Rewards Points: 256
in newer remodeliing they have these new boxes that have 1 inch flanges all around them that you tape the vapor barrier to and you have to cut all around the flange so you dont disturb the vaper barrier seal , if you dont cut around the flanges the sheetrock gets bulged from the flanges so you have to cut around the flanges which leaves a 1 inch gap all around the box that needs to be filled with durabond and taped . no big deal .
oldrivers is offline   Reply With Quote
Old 12-26-2012, 09:29 AM   #28
Rewards Points: 454
http://www.homedepot.com/p/t/2023434...8#.UNsXbHmSWwk
I have used these,and i think they work great.
scottktmrider is offline   Reply With Quote
The Following User Says Thank You to scottktmrider For This Useful Post:
rjniles (12-26-2012)
What am I Doing Wrong Here (Roller Marks, pics) dimswits Painting 13 08-01-2016 05:33 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
wrong size furnace installed - wdstkchik HVAC 6 01-06-2012 12:23 PM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Anything wrong with putting an electrical box in a kitchen cupboard beech Electrical 8 10-05-2009 05:24 AM
