Popcorn Ceiling Question: How To Smooth-out? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 09:09 AM   #1
Popcorn Ceiling Question: How to Smooth-out?
how do I skim a ceiling
carmelita is offline   Reply With Quote
Old 02-16-2012, 09:30 AM   #2
Rewards Points: 14,312
A lot more info would be nice.
If there's popcorn on there now you do not skim coat it, you remove it all down to bare sheetrock.
Wet it and scrap it all off with a drywall knife.
Old 02-16-2012, 11:23 AM   #3
Gymschu's Avatar
Rewards Points: 1,032
Joe is right. If you try to skim a popcorn ceiling several bad things are likely to happen. Applying that wet mud will reactivate whatever keeps the popcorn in place and it will more than likely fall down. If you luck out and the popcorn basically stays in place, you will dislodge enough of the popcorn to mar your skim coating attempt.
Skim coating is a very labor intensive job. After removing the popcorn, you may want to consult with a drywaller or painter on the steps needed to procede. Also, there are literally dozens of threads on here covering this exact topic.
Old 02-19-2012, 07:48 PM   #4
Rewards Points: 512
i've done a few ceilings that turned out great. i've scrapped and scrapped it then i skim coated over whatever was remaining 2 coats with either a 12 or 14inch knife.
princelake is offline   Reply With Quote
Basement ceiling question aggst1 Remodeling 9 05-07-2013 03:23 PM
popcorn ceiling (resurfacing) bryanp Painting 3 08-25-2011 05:16 AM
Painting a wall that butts up against a popcorn ceiling... hikerguy Painting 9 08-07-2011 01:56 PM
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
popcorn ceiling painting phil334 Painting 2 07-11-2008 11:23 PM
