Popcorn Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 01:22 AM   #1
Popcorn ceiling
Hi...........I took some sample of the popcorn ceiling material and sent it in to be analyzed, the result was <1%Chrysotile. What does this all mean as we are thinking of removing this material and going with texture. Thanks!
minsy is offline   Reply With Quote
Old 01-20-2011, 07:42 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
It means there is less than 1% asbestos content. 1% is the threshold for materials to be considered asbestos containing (ACM). I would still wear a respirator to remove it, but with your test results, there will be no hassles with removal or disposal. Chrysotile is one several types of asbestos commonly used in construction products.
Old 01-20-2011, 12:00 PM   #3
Popcorn Ceiling
Maintenance 6.......Thanks for the info and I am assuming that containment should also be put up to properly do this job. Should air-quality inspection be done also? Please advice..........Thanks again!
Old 01-20-2011, 04:24 PM   #4
If you want to put up containment to keep the dust out of the rest of the house, then it's a good idea. It is not needed for any kind of asbestos worry, since none exists. I personally, would not spend the money for air clearance sampling.
True air sampling, as in the kind used to clear abatement projects, is not cheap. And if you do not manage the removal process and clean up the area just the same as an asbestos abatement project, the samples will be meaningless. They will show dirty air, even though it does not contain any asbestos fibers.
Typical renovation projects are not cleaned or managed to the level that abatement projects are.
Old 01-20-2011, 09:32 PM   #5
Use a spray bottle to wet it down before you scrape it and there won't be any mess.
pyper is offline   Reply With Quote
Old 01-26-2011, 11:38 AM   #6
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
The question is, if you feel your health is still worth it or not. Should you do an air quality test. Yes. Honestly if you have it done by a professional asbestos removal company, you can't miss. It will be done properly and if you do get sick. You can sue someone over it. They also do the air quality test. To me 1% is still one percent. There is always that potential risk. it would kinda be like me telling you to put a few grains of sugar in your gas tank. would it harm it. probably not. is it a good idea. h no.
Consider your health first. and not cost of a removal.
I am a professional and this will always be my advice.
If you need a how to video about removing non asbestos popcorn go to my website below.
how to remove popcorn
stoner529 is offline   Reply With Quote
Old 01-26-2011, 01:09 PM   #7
Popcorn Ceiling
Hi stoner529,
Thanks for the advice...you are absolutly right. I found out that the popcorn material has been painted over. Any advice as to the best way of scraping this painted popcorn ceiling material? I would greatly appreciate any pointers. Thanks!
Old 01-26-2011, 04:53 PM   #8
I'm gonna guess that the popcorn ceiling in the video wasn't asbestos, since the guy scraping it off is wearing a dust mask instead of a proper respirator and no dis[posable coveralls.
Old 02-04-2011, 08:35 PM   #9
stoner529's Avatar
Rewards Points: 154
That is why i said "non asbestos"! . Even so. I try to avoid, knowingly scraping asbestos ceilings. As ive found, most homeowners just don't give a crap, and will do what people tell them what they want to hear.
If you tell them its bad but wear a mask and keep it wet. That was the answer they are looking for, so they will still do it. Even when i keep popcorn wet, I still get plenty of dust in my nose if i don't wear a mask. So that also means that dust is floating inside even if wear a mask. The presence stays in the air. Most asbestos companies will do several air quality tests doing this. One after and then one a few days later.
Old 02-04-2011, 08:43 PM   #10
Originally Posted by minsy
Hi stoner529,
They have scrapers at Lowes will work and you'll want it on a pole, but def use water. So much easier.
Waymo is offline   Reply With Quote
The Following User Says Thank You to Waymo For This Useful Post:
minsy (02-05-2011)
Old 02-05-2011, 12:02 AM   #11
stoner529's Avatar
Rewards Points: 154
Originally Posted by minsy View Post
Hi stoner529,
My advice- wet it. although painted it may still come off easy. Knifes on a pole work, but not very good on painted ceilings. it gouges them more. the best bet is a good 6 inch finishing knife. You get good pressure with it and it is less likely to tear stuff up. We remove this stuff all the time. poles work great for not painted popcorn.
The Following User Says Thank You to stoner529 For This Useful Post:
minsy (02-05-2011)
Old 03-16-2011, 01:46 PM   #12
Cover the popcorn with tin
I also have ugly popcorn in a beautiful house and it does have asbestos. I have purchased tin for a old plaster ceiling from American tin (I'm not sure of the name) but it's designed to be installed over old ceilings. Material cost is around 24.00 for a 2x2 section and we would install ourselves. Is this a good or bad plan? The day i walked into the house I looked up and felt sad.
Terrichad is offline   Reply With Quote
Old 03-16-2011, 02:33 PM   #13
Have it removed, period!!!
Don't cover it or you could be legally liable if it hurts someone in the future. Covering it up is most certainly a way to hurt someone.
pjordan4477 is offline   Reply With Quote
Old 03-16-2011, 02:34 PM   #14
@minsy
Just drywall over the popcorn ceiling, and save yourself the hassle of trying to remove it.
Old 03-16-2011, 05:53 PM   #15
stoner529's Avatar
Rewards Points: 154
In theory, if asbestos popcorn is left undisturbed, it isn't a problem to go over. You can ask a lawyer that specializes in this stuff if you can be held responsible if you install this and someone else removes it. I see nothing wrong with going over the ceiling with the tin. but the install may be a pain.
popcorn ceiling andybell Drywall & Plaster 2 09-13-2010 12:55 PM
Popcorn ceiling removal and retexturing lexter_wolf General DIY Discussions 2 05-09-2008 06:51 PM
popcorn ceiling removal and retexturing lexter_wolf Carpentry 1 05-09-2008 08:07 AM
Retexturing painted popcorn ceiling kwehnes Building & Construction 6 01-02-2007 05:36 AM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 02:33 PM
