Popcorn Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 07:59 PM   #1
popcorn ceiling
can you put 3/8th inch sheetrock over popcorn ceiling?
Vernell Lockner is offline   Reply With Quote
Old 04-17-2013, 08:05 PM   #2
Rewards Points: 13,300
On a ceiling?
I've never even seen 3/8 sheetrock.
Why not just scrape off the old sheetrock and finish the ceiling?
All the old popcorn would have to be scraped off anyway before anything went up.
Old 04-17-2013, 08:33 PM   #3
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 742
I was talking to a fellow that did this and all his seams are now cracking. Everything must now come down to the bare joists.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 04-17-2013, 08:36 PM   #4
What's the joist spacing?
Old 04-17-2013, 08:41 PM   #5
Rewards Points: 512
i know in my area of the world after plaster board they were using 3/8". i go into lots of homes with it and stores here stock 3/8" for doing patches and what not. i wuldnt recommend 3/8" for the ceiling. i'd go to 1/2" ultra light or 1/2" sag res. or you can wet down and scrape off the popcorn and skim coat it.
princelake is offline   Reply With Quote
Old 04-17-2013, 11:22 PM   #6
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
It can be done if that's the only option.
I prefer to scrape it. http://www.youtube.com/watch?v=bH04m...layer_embedded
Sometimes it's better encapsulate it. Depending on what year the popcorn texture was installed?
Sir MixAlot is online now   Reply With Quote
Old 04-19-2013, 01:19 AM   #7
Registered User
Rewards Points: 5,216
No, not 3/8" if you are applying a water-based texture- per code; http://publicecodes.cyberregs.com/ic...002_par010.htm
As per manufacturers, Table 2,"b"; http://www.lafargenorthamerica.com/G...%20English.pdf
Gary
Old 04-19-2013, 09:05 AM   #8
Too Short? Cut it Again!
Unless the ceiling is cracking badly or otherwise failing, just bite the bullet and scrape the popcorn off. If it is like the majority of such stuff it was a mix of the crappiest ceiling paint, adhesive/binder and pellets sprayed on a non-primed surface. Wet it with a tank sprayer and use a nice wide drywall knife and it should come off. You will then be done with the hideous stuff.
Lay down disposable tarps because it is a mess. I will not lie. It is not a fun job but some of us have done it too many times!
Old 04-19-2013, 09:39 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
Just know that depending on it's age, the stuff may contain asbestos.
Old 04-19-2013, 09:42 AM   #10
Rewards Points: 5,974
It's not a hard job but it's a dirty job to remove popcorn. Everyone thinks to just add another layer of drywall is the easiest way, it hardly ever is. But why not use 1/4" sheetrock if that's the way you want to go. You don't say the dimensions of the room so I hope you can use full sheets so you don't have any butts, with ceiling lighting they are hard to make go away. You didn't mention crown if it's up you need to take it down, if it's not up you should consider putting it up. Then you won't have to mud and tape where the wall and ceiling meet.
Question re. painting walls & ceiling with smooth trim alongside popcorn ceiling *pic starrysim Painting 17 07-29-2012 10:02 AM
Best roller to use with B-I-N on Popcorn Ceiling? AlaskaChick Painting 12 07-01-2012 11:38 AM
Popcorn ceiling removal and retexturing lexter_wolf General DIY Discussions 2 05-09-2008 06:51 PM
popcorn ceiling removal and retexturing lexter_wolf Carpentry 1 05-09-2008 08:07 AM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 02:33 PM
