Poll: Pull Down Or Leave Up? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
View Poll Results: What should I do with my flawed ceiling panels
Leave it up as it. Do my best to fix it in the mudding and taping stage 1 33.33%
Take down only the ceiling panels and redo them to fit a bit better 1 33.33%
Remove all panels (ceiling and walls, trim, etc) and do it right 1 33.33%
Voters: 3. This poll is closed
Old 10-12-2011, 10:56 AM   #1
Poll: Pull down or leave up? (pictures added at bottom)
Okay, so I did my first run of drywalling ceiling this week. I was using 12' panels with a hoist and since it's a repair job and some of the walls are still in place, I've gotten the panels in place but NOT all sitting perfectly in a position where the wall panels will support the edges of the panel. On three sides the ceiling meets vertical walls. On the fourth, it meets a 45 degree cathedral ceiling (ie. inside corners at the ceiling are pretty much exactly 135). The walls also, apparently, aren't exactly square, which I forget to check for before cutting the panels and now it's too late (at least for these panels) as they're too short in spots.
I'm putting my options in the form of a poll, in the hopes that I'll get maximum responses before it's too late (ie. before I put up the wall panels and start mudding). If you have a more detailed comment, please do share it, I'm happy to hear.
I'm not in an insane rush, and I'm not worried horrified about cost, so I'm willing and even leaning towards option three. I own the hoist now, as I got it on sale, so I can redo the whole thing if that's best. I can also remove the last of the walls (it's not really all that much actually) if that makes it easier/better to drywall.
wilsonstark is offline   Reply With Quote
Old 10-12-2011, 01:56 PM   #2
liscenced electrician
Rewards Points: 538
I didn't quite follow what you were saying but it sounded like you are saying.g some of the seams in your sheetrock aren't on a stud. If that's what you mean than it will not work, if you can push on a seam and there is any movement at all, it won't work. Rather than buy new sheetrock, take down the sheets and add wood nailers, so that the sheet rock has something to screw to. You can also put pieces of plywood behind your seem so that both sheets can screw to it
jimmy21 is offline   Reply With Quote
Old 10-12-2011, 02:14 PM   #3
Nope. I mean that there's spaces around the edges of the ceiling, so that when I hang the drywall on the wall studs they won't be pushing up against the ceiling drywall, but rather against the joists (in spots). Basically I can't do floating joints at the edges because the wall drywall and the ceiling drywall won't be touching.
I'd post a photo, but I'm at work. Maybe I can tonight...
Old 10-12-2011, 02:45 PM   #4
iminaquagmire's Avatar
Rewards Points: 338
As long as there is no movement in the panels, it'll be okay. If you can push in the drywall at the seams you'll likely have problems down the road.
iminaquagmire is offline   Reply With Quote
Old 10-12-2011, 02:48 PM   #5
I can screw the panels quite close to the edge, and the joists are 16" oc, so there's not much movement there. I was thinking that if I didn't replace them I might use a metal/paper or vinyl inside corner bead to give strength and bridge the gap?
Old 10-12-2011, 09:52 PM   #6
Rewards Points: 538
How big of a gap are we talking about? If there is no movement. I would just patch it. An easy way to do it is fill with expanding foam, then cut the foam flush, then tape and mud like normal
Old 10-13-2011, 01:01 AM   #7
If you find pictures helpful!
Also, if we're wanting to let me know what I did wrong, I'm guessing:
1. Assuming the corners were square was mistake number 1...
2. Trying to preserve a little bit of wall and trim was counter-productive
3. Once I knew it wasn't fitting, I should have stopped and measured WAY more carefully...
Old 10-13-2011, 10:38 AM   #8
Rewards Points: 538
Those are some pretty large gaps, id probably just mud it, but it would take some extra care. I like to put mesh tape and patch the gap with hot mud, if there is a gap like that. Then after it has dried use paper tape and mud it like you normally would. If the gap is just way too large, you could unscrew a panel and move it so that the gap is split between both sides. Gaps in flat areas are easier to patch than in corners. If its just too large of a gap you may need new pieces of sheet rock.
BTW. The proper way to do it is to sheet the lid first, then start from the top on the walls. That way you can just push the pieces tight to the lid. Then you just have small cuts against the floor that the trim covers. With a little practice, you won't have any gaps, anywhere
Old 10-13-2011, 10:47 AM   #9
Good advice, thanks. The room was damaged by water, and I'd wanted to save myself work by not taking out all the walls (including the brand new, professionally installed trim from last year), so the walls that are in place were pre-existing. I can totally understand why it's better to have no walls in place at all, and since there's only about 8 linear feet of wall left I'm thinking of just pulling that last bit of wall out, redoing the ceiling boards from scratch and then redoing the walls. May add a bit of extra work and cost, but if it spares me half-baked corner seams I imagine it'll be worth it?
Old 10-13-2011, 10:56 AM   #10
Rewards Points: 538
Depends on how good you are with mud. A lot of people I know need all the help they can get when it comes to mudding. Pulling it all down may be your best option, but id be lying if I said I would automatically pull it all down. It's your call. If you have time and money to pull it all down, then why not?
Have fun, and take your time. Getting rushed usually comes back on you in the end.
Old 10-13-2011, 10:59 AM   #11
Rewards Points: 538
Oh, and when I measure. I always measure from one corner and then the other corner. If the measurements are more than 1/4 off, ill measure the center to try to figure out what's going on.
The Following User Says Thank You to jimmy21 For This Useful Post:
wilsonstark (10-14-2011)
Old Romex? Replace or leave? HandyFrank Electrical 13 11-22-2010 03:49 PM
Pull cord light question 737Pilot Electrical 5 12-21-2008 09:49 AM
No Pull lube jamiedolan Electrical 7 12-16-2008 12:00 PM
Pull / jbox out of A panel box jamiedolan Electrical 5 11-22-2008 11:51 AM
