Please Help Me Patch This Tiny Hole - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 03:07 PM   #1
Please help me patch this tiny hole
Hi DIY,
I have a little 2" square hole I cut near the baseboard with a keyhole saw, and am moving out so it's time to patch 'er up. What method(s) would you recommend for a novice to get this looking good?
whatupdun is offline   Reply With Quote
Old 01-25-2012, 11:15 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
You need to jam a drywall or anything for that matter plug into the hole, leaving it recessed about 1/16", then fill with spackle or drywall mud, using a trowel or a spatula. Paint.
If it was any bigger, ( It looks like about an inch) I'de clean up the hole (make it square) and fit a piece of drywall back in it.
When you cut the piece of drywall, leave the paper facing about an inch bigger all the way around. This will serve as the drywall tape.
Butter some drywall mud around the hole and push the plug in with the bigger paper facing.
Use a trowel or a spatula and scrape the excess mud out from under the paper.
Let dry, then wipe another layer of mud over it.
After that's dry, sand lightly, then try dabbing some fresh mud with a brush or a sponge then lightly dragging it back down with your trowel to match the texture as best as you can.
Paint.
Edit: I see it's about 2". Use the second suggestion.
titanoman is offline   Reply With Quote
Old 01-27-2012, 08:14 AM   #3
Rewards Points: 1,428
That texture is going to be a pain, but Titanoman has good advice. Good luck. Post up how it turns out.
And you might want to try to scrape the texture off about 4 inches around the hole before you start to compensate for the material you will be adding later on.
mikegp is online now   Reply With Quote
Old 01-27-2012, 11:12 AM   #4
Disabled wood vet
titanoman's Avatar
I was going to suggest that but I thought they would probably tear up the drywall trying to scrape it.
But your right, it'll never be invisible if you're looking for it.
Old 01-27-2012, 12:30 PM   #5
Old School
Willie T's Avatar
You can match that particular texture pretty close by slopping up some drywall mud real wet (like thick milk), then loosely wad up some newspaper and dip it in the milk mud. Dab at the surface, pulling the wad of paper straight away from the wall.
Willie T
How to remove outlet from tiled wall, then patch drywall and retile? Jakobud Kitchen & Bath Remodeling 18 10-15-2011 05:05 PM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 10:57 AM
How To Support A Drywall Patch For Hole In The Wall? dsq Drywall & Plaster 7 02-23-2009 03:48 PM
Patch a hole in the bathroom tile sw41 Flooring 1 12-07-2008 01:57 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 11:16 AM
