PLEASE HELP!! Drywall & Stove Pipe Issue - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-13-2014, 12:49 AM   #1
PLEASE HELP!! drywall & stove pipe issue
I have an older home & I'm guessing whomever installed the wood stove, pipe was not thinking.. IDK.. I have a Franklin wood stove & the pipe goes from a 6" single wall to an 8" triple wall stove pipe at the ceiling. Which is correct, it is braced correctly and the pipe from the ceiling threw the attic out to the roof tp is correct. What is NOT correct is it goes from single to triple wall with NO reducer/increaser. I've just recently noticed there was something wrong because my ceiling around the stove pipe has started to droop. Upon further investigation, the reason it's sagging is because water has leaked on the drywall and slowly weighted it down to where I'm going to have to replace the drywall.. here's the dilemma.... The water is NOT leaking from a hole or spot in roof, its coming from INSIDE the stove pipe. IDK if it's condensation or what, but when it happens it's from a slight drip to a flow of water. (almost like someone is on the roof with a glass of water.) It's done it when there hasn't been any snow/rain in days. I would like to know if anyone has ever had this issue, if anyone has an explanation as to why it would drip from INSIDE the triple walled pipe & if I put an increaser/reducer on will the water evaporate instead of running down the remaining pipe?
kgriffberg is offline   Reply With Quote
Old 02-13-2014, 04:53 AM   #2
DIY staff
Rewards Points: 7,174
A couple of possible issues---
8" is rather large for a Franklin stove--how tall is the 8" section.
The sections may be installed upside down---is the flared part with the locking band on the top of each section?
Are you absolutely sure the leak is not from the roof collar?
What kind of cap is on the chimney ?
Tags
ceiling , drywall , stovepipe
Drywall and Ceiling register issue shiarua Drywall & Plaster 8 02-03-2014 06:33 PM
Bathroom Remodel - Trim / Drywall Issue medic8106 Remodeling 7 09-29-2011 09:52 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Stove pipe through roof overhang IDIY Roofing/Siding 2 08-12-2010 11:55 AM
Crinkles on full wall drywall seams. Big issue? bteudt Drywall & Plaster 9 06-30-2010 04:16 PM
