Plastic Behind Baseboards - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 06:27 PM   #1
Plastic behind baseboards
I bought an older house. It has hardwood floors, and various combinations of lath/plaster, drywall, and fake wood panel stuff. At the base of the walls is the baseboards, which I removed to paint and/or replace. Behind these wood baseboards along the entire length is a piece of plastic. Thin sheet stuff.
Has anyone seen plastic behind baseboards before? Is this plastic for some function? Do I need it, or should I remove it?
Kaell is offline   Reply With Quote
Old 01-23-2012, 07:39 PM   #2
DIY staff
Rewards Points: 7,174
Remove it---Never seen that---can't think of one good reason for it,either---
Old 01-23-2012, 08:22 PM   #3
Love for Construction
<*(((><'s Avatar
The plastic was put under and up the walls when they laid the hardwood floor as a moisture barrier in case of water leaks in other rooms or of high moisture concrete.. Leave it and just install the new baseboard over the top of it.
-luke-
<*(((>< is offline   Reply With Quote
Old 01-23-2012, 08:28 PM   #4
Rewards Points: 12,868
That was my first guess to.
Far more common to see rosin paper or tar paper.
Tags
baseboards plastic
Plastic baseboard vs crown moulding baseboards daluu General DIY Discussions 17 01-29-2012 09:05 AM
Redgard vs 6mil Plastic Sheeting for tiling amodoko Remodeling 0 01-18-2012 12:57 AM
Clear Plastic Baseboards trackhed Drywall & Plaster 0 01-13-2011 03:50 PM
Masking off baseboards 2 PaintedSurface Painting 1 01-18-2010 05:30 AM
Plastic plywood, Plastic sheets, Plastic decking Spud Building & Construction 1 10-16-2009 05:43 AM
