Plastering Is Bleeding Through Paint Help!!!! - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-28-2013, 11:26 AM   #1
Plastering is bleeding through paint help!!!!
Hi guys, I found this site and hoping I can get some help. I am doing a reno in my basement and building an office, this the first time this is happening to me and hoping it can be resolved. I had to re-plaster the drywall seam as it was cracking all the time, so I put some more screws on and then taped and plastered and then sanded and then primed. I bought this primer from homedepot http://www.homedepot.ca/product/prem...er-379l/939035
Everything was great until I painted the walls, I can see where I re-patched on the seams, the ceiling looks great but the walls dont. I replied some primer and then another coat of paint and still I can see the plastering that was done. I read online that I need to use a kilz stain blocker http://www.homedepot.ca/product/kilz...7#BVRRWidgetID
so I was wondering would I have to resand the seam and then apply the primer? Or should I add a thin layer of plaster first? This is the first time it happen to me, BTW oil based primer is not an option. I have inserted some images to show you guys
Two options why I think this happened, 1) I ran out of the main plaster bucket so I went out and bought another one same brand but smaller but the color was darker, 2) Could be and I think I used the white paint instead of the primer when I re-plaster the seam, the white and the primer rolls was right next to each other. Any info is much appreciated
https://www.dropbox.com/s/x96009btxvv0sfp/plaster.jpg
https://www.dropbox.com/s/4m0n9iip27l29c0/plaster1.jpg
https://www.dropbox.com/s/722n1oc85gd4jfo/plaster2.jpg
black_escape is offline   Reply With Quote
Old 08-28-2013, 11:38 AM   #2
Rewards Points: 12
Based on this picture, if the gray area is all you added for drywall compound then you didn't feather it out far enough. That's why you see it. It's not a paint issue.
Dan
djlandkpl is online now   Reply With Quote
Old 08-28-2013, 11:41 AM   #3
Okay so how can I resolve the problem now? After it has been painted?
Old 08-28-2013, 11:52 AM   #4
Rewards Points: 12
Add a thin coat spreading it out 10 to 12 inches out from the center for a total of 20+ inches. Then sand.
Dan
Old 08-28-2013, 11:54 AM   #5
okay so nothing to do with the primer then? I assume that how it looks when its not spread enough
Old 08-28-2013, 11:57 AM   #6
Rewards Points: 12
Correct.
Dan
Old 08-28-2013, 12:06 PM   #7
Thanks will give it a try and get back to you.
Old 08-28-2013, 12:40 PM   #8
Dan
Would I have to prime the whole wall or just that area?
Old 08-28-2013, 01:45 PM   #9
Rewards Points: 12
Dan
You can prime just the new area.
Dan
Old 08-28-2013, 08:21 PM   #10
Rewards Points: 5,974
You keep using the term plaster, I hope you mean joint compound. Also if you used paint instead of primer that could be part of the problem. Paint over joint compound will absorb different than on the drywall. I kind of disagree with the advice of putting another coat on. It already looks like it's high another coat will make it higher. You need to sand some of what's on there off, then a thin coat feathering it out. But since it's a tapered joint a 12" knife down the middle should be enough.
Old 08-29-2013, 08:24 AM   #11
ToolSeeker, yes I meant to say compound, I re-sanded the area and applied a thin layer using a 12inch knife, we shall see how it goes.
The Following User Says Thank You to black_escape For This Useful Post:
ToolSeeker (08-29-2013)
Old 09-01-2013, 02:19 PM   #12
I am thinking it is a paint issue for the reason given by Toolseeker: the "plaster" or dry wall compound when dry surely needs to be sealed with a primer pior to applying a top finishing coat. If it is not sealed well then the color of the dry wall compoind will show through and create a difference in shade betweeen the different zones.
angusmdmclean is offline   Reply With Quote
Old 09-01-2013, 02:34 PM   #13
Turned out I put a light layer of compound and then primed it twice and painted and all is good. Thanks for your help guys
ToolSeeker (09-01-2013)
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
1st Steps in Painting? Qckrun Painting 7 12-15-2009 01:25 PM
paint bleeding jpg274 Painting 6 11-16-2009 08:01 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
