Plaster Walls And Wood Over? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 06:32 AM   #1
plaster walls and wood over?
Greetings,
My walls are the old plaster type and I have always hated them. Is it possible to put knotty pine over them, and how much prep would be involved? I really love the look of the old barn board. -Diane
Carrotcake is offline   Reply With Quote
Old 07-11-2012, 05:46 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
possible? yes, a diy job? probably not
Old 07-12-2012, 04:15 PM   #3
Too Short? Cut it Again!
You would be adding a lot of weight so should demolish the lathe and plaster. You are going to need to have structure to nail the barn board to anyhow. Your outlets and switch boxes are going to have to be moved forward or you can get extenders.
If the wall are flat, you might be able to get away with that thin "faux barn board" stuff. It will look awful and be a nightmare if your walls are not flat.
Old 07-12-2012, 09:19 PM   #4
Rewards Points: 14,010
Best to loose the plaster and lath. Your going to have to put up horizontal strips of 1X's to have something to attach the boards to.
I hope your not planning to sell soon. your one of the few people that would want that type walls.
Notty pine went out of fashion many many years ago.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Ebonizing wood paneled walls? TOTALN00B Painting 3 08-05-2011 10:16 PM
Painted wood walls - couldn't take the depressing darkness! mrs1885 Project Showcase 6 01-09-2011 10:03 AM
Remove half walls & replace with wood railing/balusters jjgoss Remodeling 3 06-29-2010 08:05 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
