Plaster Walls With A New Drywall Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 05:57 PM   #1
Plaster walls with a new drywall ceiling
the plaster ceiling is already gone but the walls are intact. In order to get a gap at the top of the wall for the ceiling drywall to slide into is a problem. I am having a contractor do the ceiling and he has requested that this be done. There is a wire mesh under the plaster that goes all the way to the ceiling. The question is: what is the best way to cut out 3/4 of an inch of wall with that wire there. Or is there a better way to do it?
My idea was to just cut a 3" strip off at the top of the wall and replace it with drywall, but he doesn't like that idea.
Johnstrant is offline   Reply With Quote
Old 03-05-2012, 07:09 PM   #2
Rewards Points: 12,818
It would be better is there was a gap but I see no reason why anyone should go through all the extra work of going back and doing it now.
Just install the sheetrock as tight as they can to the wall and use hot mud to fill the gaps.
You would have to snap lines and use an ossilating saw to make some smooth cuts.
A 2" wide piece of rock is going to flex inless you added backers between every stud bay, a royal pain.
Old 03-05-2012, 08:23 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
They just want that so they don't have to nail off that edge of the ceiling sheetrock.
titanoman is offline   Reply With Quote
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Replacing drywall ceiling only, not walls shan1616 Drywall & Plaster 10 11-15-2009 04:15 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 08:30 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
