Plaster Walls, Holes From Switch Boxes - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 05:38 PM   #1
Our electrical upgrade is progressing nicely. I have quite a few empty holes in my plaster walls where old switch/outlet boxes used to be. What's a quick and dirty, yet solid, method to fill the holes and blend them in? Thanks everyone in advance.
Demo Dick is offline   Reply With Quote
Old 12-10-2011, 06:22 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
re:Plaster Walls, Holes From Switch Boxes
quick-no,dirty-yes.solid=best I've found.
do not try to fill boxes with anything! get some 5/8 drywall. the boxes are usually like 2"x3"? cut pieces of 5/8 drywall 4"x5", turn drywall pieces over and score inside paper to 2"x3" or size of boxes,
remove inside paper from box size and scrape off gypsum, leaving only outside paper as smooth as possible having at least 1 inch of paper all around hole. then use drywall Spackle and apply Spackle around perimeter of box.
put pieces of 5/8 drywall with only the paper over hole and Spackle it in. the paper will serve as drywall tape, then with arched knife or trowel apply two more coats over entire thing after has been completely dry.
let dry completely between coats coat and feather out edges until you're satisfied with blending in. May never be completely perfect? but will allow you to feather it out to suit yourself.
as usual, just my thoughts
good luck
coupe
coupe is offline   Reply With Quote
Old 12-11-2011, 12:41 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
There's no reason why coupes method shouldn't hide completely in 2 or 3 muddings.
titanoman is offline   Reply With Quote
Old 12-11-2011, 04:40 PM   #4
Sounds good. Thanks folks.
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
Plaster Walls? I dont know? chsitko Drywall & Plaster 4 08-28-2010 05:30 PM
What are the holes on the back of a light switch? Is that different than screwing? abefroman Electrical 6 08-01-2010 12:56 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
