Plaster Wall Repair - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 01:25 PM   #1
Plaster Wall Repair
My house was built in 1919. It is all plaster and lath except for the terrible drywall remodel in the kitchen. The plaster is in good condition(I think) except for multiple small spider cracks in each room. I want a clean drywall look to it without all of the little cracks. What are my options? I am already moved in and really want tearing down the plaster to be a very last option. Thanks.
lierman44 is offline   Reply With Quote
Old 03-09-2011, 04:18 PM   #2
Drywall contractor
Rewards Points: 1,070
Go to warehousebay.com and check out their products listed under "Interior Walls, Drywall & Plaster". They have several product that come in rolls that can be used for the "spiderweb" cracks on larger areas than regular tape would cover. Use a setting type compound for at least the first coat, then regular ready mix for finish coat(s). The product called Nu-wall is actually a system for "wallpapering" the entire wall(s) if the damage is that bad.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-09-2011, 04:52 PM   #3
I checked out the website. That stuff looks great. I am going to try it out. Have you had any experience with it? Does it last if done properly? Thank you so much for the info.
Old 03-09-2011, 06:23 PM   #4
Drywall contractor
I have used the Fiba-Fuse products with good results. Haven't tried the Nu-Wall, but have read good reviews on trade related web sites....
Old 03-09-2011, 09:12 PM   #5
Learning by Doing
Leah Frances's Avatar
Take pics and report back. I've got 200 year old plaster and one room with spiderwebs. I would love to know how this turns out for you.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Moisture on plaster wall? (How do I troubleshoot this?) aengblom General DIY Discussions 7 03-02-2011 04:55 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Need to fix old plaster on brick wall - any hints? Leah Frances Building & Construction 1 01-14-2010 05:55 AM
Drywall and Plaster Repair argana Building & Construction 8 09-15-2007 02:13 PM
