Plaster Texture For 1923 Craftsman - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 12:23 PM   #1
Plaster Texture for 1923 Craftsman
I am a novice restoring a 1923 Craftsman bungalou. The old lathe and plaster has little bumbs (like large sand particles in the in the fiinsh)
How can I reproduce that texture<
JTasoff is offline   Reply With Quote
Old 09-10-2012, 02:54 PM   #2
Rewards Points: 582
An open grained finish with lime plaster is obtained using sharp sand/lime mix and finishing with a wooden float.
stuart45 is offline   Reply With Quote
Old 09-11-2012, 12:08 AM   #3
Sounds easy for the average novice DIY'er. Do really mean thanks.
Jack
Old 09-20-2012, 03:14 PM   #4
Too Short? Cut it Again!
Might be sand in the paint? You can buy washed sand at the paint store. Mix it with paint in a separate container from the original can and keep track of your proportions so you can reproduce the texture you like. The make a special roller cover for applying sand finishes.
I don't think you can put a lime finish over existing latex paint but it has been awhile since I thought about it.
I am assuming you are trying to reproduce a paint finish of course. The other post makes more sense if you are doing new walls on the lathe.
Tags
plaster repair
Plaster Texture for 1923 Craftsman JTasoff Drywall & Plaster 0 09-10-2012 11:59 AM
Tips for matching the texture of plaster? Ptron Painting 3 09-15-2010 02:59 PM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Can you texture plaster walls? destes50 Painting 5 11-06-2009 09:51 AM
Texture to plaster bofusmosby Remodeling 2 05-05-2008 07:33 AM
