-   -   Plaster Texture for 1923 Craftsman (http://www.diychatroom.com/f101/plaster-texture-1923-craftsman-156410/)
JTasoff 09-10-2012 01:23 PM
I am a novice restoring a 1923 Craftsman bungalou. The old lathe and plaster has little bumbs (like large sand particles in the in the fiinsh)
How can I reproduce that texture<
stuart45 09-10-2012 03:54 PM
An open grained finish with lime plaster is obtained using sharp sand/lime mix and finishing with a wooden float.
JTasoff 09-11-2012 01:08 AM
Sounds easy for the average novice DIY'er. Do really mean thanks.
Jack
user1007 09-20-2012 04:14 PM
Might be sand in the paint? You can buy washed sand at the paint store. Mix it with paint in a separate container from the original can and keep track of your proportions so you can reproduce the texture you like. The make a special roller cover for applying sand finishes.
I don't think you can put a lime finish over existing latex paint but it has been awhile since I thought about it.
I am assuming you are trying to reproduce a paint finish of course. The other post makes more sense if you are doing new walls on the lathe.
