Plaster Skim Coat Over Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-15-2013, 11:40 AM   #1
Rewards Points: 93
Plaster Skim Coat over Drywall
Please forgive me if this topic has been addressed before.
I am adding a wall in an older house. I plan to use 5/8 inch US Gypsum drywall with a skim coat of plaster over the top. One of the guys who wants to do the plastering says I should hang the drywall backwards. He says adhesion to the rougher paper on the back side is better for the skim coat of plaster and that this is perfectly legal. I have never heard of this before.
Any comments?
Perry401 is offline   Reply With Quote
Old 04-15-2013, 12:09 PM   #2
Rewards Points: 626
Any comments?
Um you should be using plaster board the blue sheets not drywall. If you use plaster board you use plaster for the skim coat. Drywall you use dry wall compound for the skim coat.
Nailbags is offline   Reply With Quote
Old 04-15-2013, 01:29 PM   #3
Rewards Points: 13,274
I'm still trying to figure out why you would not to skim coat it in the first place.
A whole lot more work.
Old 04-15-2013, 06:00 PM   #4
Rewards Points: 5,974
As stated blue board is for plaster. Have never heard turning the drywall around will make a difference it sure won't hurt anything. I have finished some that was put up backwards by mistake. If it makes him feel better why not.
skim coat or replace the drywall Renee5315 Drywall & Plaster 8 03-30-2013 10:11 AM
Matching drywall to plaster paintdrying Drywall & Plaster 4 03-04-2013 02:57 PM
fixing previously botched finish plaster over scratch coat twd1 Building & Construction 2 01-31-2012 10:29 PM
Second topcoat blisters over clean skim coat norepeat Painting 8 09-07-2011 07:30 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
